Question about Craftsman Saws
V-belt broke need to know how to replace the belts
    Brigadier General:
  • 4,088 Answers
On my older 10 inch Craftsman, the motor hangs on a hinge device. All that is necessary is to lift up on the motor and slide the belt off of both pulleys. Take the broken belt to Sears, a nearby hardware store, or auto parts supply house. They should be able to get you an exact (or nearly so) replacement. Buy a segmented type if you can which travels around small pulleys with more ease and is just as durable. Hope this helps!
Posted on Oct 23, 2010
SOURCE:
How do I remove the altinator belt and replace the supercharger with a new one? just so you guys know... MINE IS DONE FOR NOSE BROKE AND BEARING CAME OUT AND ITS SEIZED. PLUS PULLEY BROKE IN HALF.
Sorry to hear that. Few people know the supercharger has its own oil. It needs to be checked and refilled as the car ages.
There is a spring loaded belt tensioning device....you need a socket that fits the bolt (some have a square hole for a 1/2 breaker bar) you take the tension off the belt and slip the belt off the most convenient pulley.
Oct 24, 2013 | 1995 Buick Riviera
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the...
could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Jul 30, 2013 | Garden
I need a timing belt diagram for a 1995 dodge caravan 3.3
The 3.3 L Caravan engine does not use a timing belt.. It is timing chain set up. What belt are you talking about that broke?? The serpentine belt that drives all the accessories??
Jan 30, 2013 | 1995 Dodge Caravan
Timing belt replace escort 2000 engine
Don't know what answer your looking for !
I would ask -- why did the belt break,I change them
every 6 years & inspect a couple times a year
You remove the belt & debris from it,replace the
broken cover if necessary, with a used one, & replace
any damaged sensor & repair any wiring
If you never work on your own vehicles,then we can't
direct a repair shop as to how to do what they choose to do
If you need to do a timing belt, then you watch a You Tube
Video about that, on your specific car & the diagram should
be on the belt sleeve, if you get a gates or quality belt
Sep 29, 2012 | 1997 Ford Escort
Serpentine belt broke on my 2003 mazda tribute
just loss of power to accessory's unless the timing belt jumped a tooth or more.
Jul 08, 2012 | 2003 Mazda Tribute
Need diagram/info on how to set timing belt for 1992 Lexus LS 400
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Feb 22, 2012 | 1992 Lexus Ls 400
Serpentine belt broke is the engine ruined
serpentine belt no timing belt maybe yes know as a interferece engine but the serp.. belt should be fine just replace
Dec 29, 2010 | 2000 Ford Escort
Timing belt broke need to know how to time 1.9 4 cylinder
if your timing belt is broke,you should be looking at a massive repair bill and not worring about how to replace a belt.sorry.adrian,,,,
Jul 03, 2010 | Ford Escort Cars & Trucks
Just broke timing belt on my 300zx,does thi
Yes your engine is a interference engine,
which mean valve to piston hit.
But replace the timing belt.
Possible you didn't bent a valve.
Depend on the condition when the T/B broke,
Let me know.....
Sep 29, 2009 | 1985 Nissan 300ZX
Saws Logo
81 people viewed this question
Top Craftsman Saws Experts
Mike
Thomas F. Schneider
John Trevino
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
