Question about Insignia Sport MP3 Player
Big problem My MP3 keeps on frezing when i try 2 charge it wat should i do
  • 4 Answers
Ackman., does it freez on the same song every time?
Posted on Jul 08, 2008
Something could be wrong with your USB port (get it checked out at bestbuy)
Posted on Jun 07, 2008
I try 2 put it in my pc with using usb it said low battery and it keeps saying that over and over i tried 2 keep it off for days but it still keeps saying low battery i dont know wat 2 do i tried...
Please check the player using another PC to confirm if there are any faults on the USB of your PC. If the same fault repeats, connect to remove all files, format the memory and see if the charge holds, in case the player is hanging up.If so the battery is faulty within and you need to seek an estimate.
Nov 30, 2011 | Audio Players & Recorders
I have been trying to charge my sandisk 2GB sansa and its not charging what seems to be the problem can it be fixed. All it says battery is low and switches off again
There are two possible problems:
1. the usb cable you are using is not working
2. the charge section of the Sansa is damaged.
does it start charging any at all, if it does then it could be a the charge section. If not it might be the cable. Try getting another cable to borrow that works or try using ur cable to charge another player, to see wat exactly is the problem.
The screws at the back of the sansa mp3 player can be taken out given u direct access to the battery, which can be taken out and charge with a universal charger. (be careful not to damage anything)
Jul 20, 2011 | SanDisk Audio Players & Recorders
I dont no wat to do with it and i dont no wat it meens
this is a 2G player for listening musicwith the headphones or on a audio system...You have to connect it to a computer to load mp3 files(music ) on it ..and after that it is capable to play them ..(to go )..
it uses either batteries or it has a built in battery that can be charged eiter with a charger or from the usb connection with the computer ..
Dec 21, 2010 | iLO (2 GB) MP3 Player
My mp3 player wont charge it just says ok to disconnect please help
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............
Just make sure it is not Locked or On Hold and then try to charge it.........
Good Luck
Jan 22, 2009 | Audio Players & Recorders
Rca screen help
On the back of the the mp3 player is a reset switch.
Hold that down about 15 seconds.
If that does not work go to the RCA website.
Download the latest firmware.
Plug mp3 player into pc.
Install the new firmware.
Keep it plug to computer for about 1 hour to charge the battery a little.
Dec 23, 2008 | RCA M4204 MP3 Player
My mp3 dosent work!!!!!!!!!!!!!
mine did this too when it was new, just hold down the menu/power button for 15 seconds, depending on how fast your counting you might have to hold it down longer.. that will reboot it (sometimes it delets the tracks, just warning you) and other times it just restarts it.
Nov 30, 2008 | SanDisk Sansa e250 MP3 Player
Sandiskmp3 player
it may be a loose battry connection. try opening the player and reseating the battery. if that does not work, you may have to get a return from sandisk if your warrenty is still valid.
Jul 28, 2008 | SanDisk Sansa E280 MP3 Player
I need help big time
you need to download sonic stage for the player( if its a sony digital player) ive got the NW-E005 and that need sthe sonic stage
May 29, 2008 | Sony Network Walkman NW-E005 MP3 Player
Mp3 player won't charge
r u pluging it into the computer or you can use an x-box 360 if you buttons freze it's just that it's been on for a while and need to cool down once you put in it in the computer (the use of charging) it should go back to normal mine was doing that yesterday
Jan 06, 2008 | Memorex MMP8565 MP3 Player
It keeps freezing
I would recommend you to upgrade your device firmware...that should solve the problems you are having...
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Insignia Sport MP3 Player Logo
47 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
