Question about HP Photosmart 2610 All-In-One InkJet Printer
New color cartridge will not print magenta - HP Photosmart 2610 All-In-One InkJet Printer
  • HP Master
  • 7,733 Answers
Go to LINK.
Posted on Oct 24, 2010
SOURCE:
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
Magenta & light magenta not printing photosmart c6180
The ink level in the color cartridge has three different colors in it. You may need a new cartridge. Magenta is usually the first to go out.
Dec 14, 2017 | HP LaserJet Office Equipment & Supplies
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Prints only green predominently
Without knowing what printer you have or what things you have tried I can only guess here. It sounds like you need a new cartridge. A color ink cartridge will have 3 colors of ink for most printers...cyan (blue), magenta (purplish-maroon), and yellow. Depending on what you print it is very possible that you could run out of one of the inks before the others. Printing green can be an indication that you are out of magenta ink. The cyan and yellow inks will combine and look green.
You can remove the cartridge and run a tissue over the printhead and see if you see all 3 colors as a quick test. If you only see cyan and yellow, then the magenta is probably empty or dried up. If you see all 3 colors I would reinsert the cartridge and try printing again. It is possible that the magenta was just clogged and you cleaned it with the tissue. If it still doesn't print all colors your best bet is probably to just get a new ink cartridge.
Sep 10, 2008 | Office Equipment & Supplies
Color problem
Chances are your othe cartridges were low...
When you install a new cartridge your printer does a head cleaning, and it uses alot of ink...
If the others were low, your printouts will show magenta as its the only color left...
Feb 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
22 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
