Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
My bissell proheat turbo won't spray water from under the bottom it just stopped all of a sudden. where whould i look for the clog.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 ...,,/
Posted on Oct 28, 2010
SOURCE:
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
What causes a carpet cleaner to stop spraying water?
Can only think of 2 things - pump or clogged spray nozzles.
Regards,
Dennis
Aug 22, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
WON,T SPRAY CLEANER/WATER CARPET IS DRY.THE TOOL ATTACHMENT WORKS OKAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Sep 08, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat sprays water when first turned on, then after a minute stops spraying
heatman101
oiguut
Jul 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No water spraying out
go to bissell.com. under feq askes questions. Also speak to or e-mal someonee from customer service.
Jul 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
No water or solution spraying
Used an air compressor to clean out the clogged tubes
Jul 18, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
1,860 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
