Question about Linksys WRT120N Wireless Router
Hi, I own a LInksys Wireless Router WRT120N. The internet works fine through it but my iPod and Blackberry have trouble connecting to the internet through WiFi. They can see the network, and the WiFi symbol does show up on my iPod, but I can't access the web with either my iPod or BlackBerry through WiFi. How do I fix this problem?. Thanks in advance.
  • Linksys Master
  • 7,733 Answers
Posted on Oct 24, 2010
SOURCE:
Linksys wrt120N router serup
Please connect the router and open 192.168.1.1 and enter the login page of the router with
username=blank
Password =ADMIN
Once you are in the router page select the basic wireless settings.
Under this if you want you can select the security.
Once this is set
save the settings.
Will wok fine.
Apr 23, 2013 | Linksys WRT120N Wireless Router
Cannot connect to Wireless with my Linksys WRT120N Router.
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
Feb 09, 2012 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Why can't I get my tablet PC to connect with my new Linksys Wireless-N Home Router?
Hello, Try troubleshooting:1) Does it have a password on your router?2) If so remove password and try connecting to it
Some electronics cant work to connect to WiFi if its protected by a tough security such as WPA2-TKIP.
Nov 14, 2011 | Cisco - Linksys Wireless-n Home Router -...
My wii will not connect to my linksys wireless router
Is it a new router? Your Linksys WRT120N needs resetting. Reset the Linksys router & reconfigure as per your requirement. I had two such routers giving trouble for the WiFi connectivity & which were new. You will be able to connect your router.
sonsunny
Jul 08, 2011 | Linksys WRT120N Wireless Router
I want to connect d'link 2640t to linksys wrt120n, hi i have a DLink 2640T modem+router with IP 192.168.2.1, i want to extend my home network so i bought a WRT120N router with IP 192.168.1.1, i am...
This is too involved to just post your router settings. I would recommend reading up on how to "cascade" your router or to make your Modem/Router act as a bridge.
The dlink will need to have its DNS disabled and have the Linksys do the DNS. Then the LInksys will be using the Dlink as its host. you may be better off seeing if you can make the dlink run in Gateway mode instead of router mode.
Then see how to implement the cascading router with your particular situation and WAN IP.
Jan 02, 2018 | Linksys WRT120N Wireless Router
I set up my WRT120N router. My desktop is connected to the internet with the provided ethernet cord, but my friend's macbook cannot connect wirelessly. He keeps getting a "timeout" message. ...
You Linksys wireless settings ie. SSID and encryption etc these settings are needed to configure the wireless card in the MAC so it can connect to the Linksys.
Dec 04, 2010 | Linksys WRT120N Router
WRT120N how to enable wireless option
Wireless should be enabled by default on the router. Check whether you have switched on wireless on your laptop.
Please rate if helpful.
Thanks
Apr 13, 2010 | Linksys WRT120N Router
Linksys WRT120N Wireless Router Logo
379 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
