Question about SanDisk Sansa Clip MP3 Player
Sansa Clip has stopped altogether during charging. Stuck in the "writing" phase. I cannot shut off.
  • 2,382 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first.On most models, restart is done by holding the power button in for 15 seconds or longer.Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start ? Control Panel ?System ? Hardware ? Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
Posted on Oct 23, 2010
SOURCE:
SANSA CLIP MP3 FROZE WHILE CHARGING
try removing the battery and putting it back in and see what happends. i not sure this will work
Jun 03, 2012 | SanDisk Sansa Clip MP3 Player
My Sansa clip is stuck in the writing mode
hold the power button up for 10-20 seconds to shut it off and turn it back on,,, also i suggest updating your firmware on the device!
http://mp3support.sandisk.com/sansa/Installer/1083/SansaUpdaterInstall.exe
Jan 19, 2010 | SanDisk Sansa Clip MP3 Player
What's wrong?
i suppose your batteries are busted. try replacing them
Jun 07, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Charger doecnt work properly
On your computer, go to Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager --> and uninstall the item marked MTP device. It will be a bit tricky b/c the Sansa will cut in and out during this process.
Uninstall all Sansa software, and reinstall the clean version from Sandisk's website.
-Tha Mp3 Doctor
Jan 09, 2009 | SanDisk Sansa Clip MP3 Player
My sansa mp3 player wot turn on
Actually there's none so think about buying a new charger and if it's not working then re-write to me so that I can help you more.
Sep 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip Mp3 Player
format it
by connecting to computer
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2g breakdown
Get the firmware update from Sansa's website, and then restart your computer.
http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
241 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
