Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Hello; I have a 911.9378710 electric range. I cannot get the oven to heat up. I just did an electric cleaning yesterday, which went well.
5 Suggested Answers
SOURCE:
fridgetech
  • 473 Answers
SOURCE: Error code F3 on Kenmore 911.4658815 electric range
The oven temp. sensor has gone bad.  Replace it and that will solve your problem.  The part # is WB21X5301 and cost is $73.49.  Can purchase at http://www3.sears.com/.  You can view the image at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124160&brandID=0582&modelDesc=Free%20Standing%2C%20Electric&modelNumber=9114658815&documentID=00053545&documentTypeID=PLDM&documentClassCode=PM&titleType=BODY%20SECTION&titleID=00002&.  It is inside the oven in the upper right or left hand corner.  Should be able to remove from the inside.  Two phillips screws and pull it out harness also.  Plug new one into harness and put screws back in and you are done.
Posted on Oct 17, 2007
milten1
  • 1304 Answers
SOURCE: kenmore 911-4658811 will not set or heat up above 170 degrees
pull the range out, unplug it, remove the small tin door, ohm out your bake element,
if its gas well then thats your ignitor
Posted on Oct 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Electric Self Cleaning Range
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Electric Range - Surface heats up fine,
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Oct 01, 2010
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
My kitchen range oven is not working. every things looks fine , timer is on ,tiking sound coming but element is not heating up what went wrong
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 18, 2010 | Frigidaire FEF336BC Electric Kitchen Range
We've a Whirlpool Gold Accubake System (electric). Yesterday, the oven was working fine, we did a cleaning and today when we went to use it and it would not heat up. Is there a way to determine if the...
its not uncommon to have this happen. it may have overheated . causing the hi limit on the back of oven to fail, that is what you need to ck . and repl if you find it to be bad. **** .. if your want to ck the element then when the back is off range . you can ck the two elem with a ohm meter . . ****
Dec 25, 2009 | Ovens
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
My oven will not heat up at all.
make sure your cooking timer is on manual....
Feb 01, 2009 | Whirlpool RBS305PD Electric Single Oven
Kitchen aid single electric oven
soundsl ike youve blown a thermostat on the back wall of the unit(fairly common with the K/A appliance, unit wikk have ot be pulled out to check continuity on the thermosts( loactated behind back wall just between the broil element hook ups.
Apr 02, 2008 | KitchenAid KESC307 Electric Kitchen Range
Estate Range #TE5400PXHQ0
MY SELFCLEANING WHIRLPOOL OVEN CLEANED ABOUT 30 MINUTES AND THEN STOPPED AND WENT INTO E2 AND F1. THE DOOR IS LOCKED AND WON'T OPEN. WE HAVE TRIED EVERY THING THE BOOK SAID AND NOTHING HELPS. DO YOU HAVE AN ANSWER?
Dec 20, 2007 | Whirlpool RF368LXKS Electric Kitchen Range
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
46 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
