Question about HEWLETT-PACKARD HP Consumer Pavilion dm41063he Notebook
I have hp pavilion dm4 bought in india and plan to ytravel to usa. What should i do about adapter. India is 220 and different electrical outlet from 110 us? please advise
    Master:
  • 362 Answers
Hello, take a close look at the writing on the label of the adapter. Usually it says (somewhere near the bottom) :
INPUT: 100-240 ~ 1.6A
If it says this, then its a universal power adapter (and HP ones normally are) and automatically adjusts between 110v and 220v. All you've got to buy, then, is a suitable travel set to plug your adapter into the US wall socket.
Regards,
Nicam49
Posted on Oct 23, 2010
  • nityatakumar
    nityatakumar Aug 01, 2012
    hey wat exactly do u mean by travel set ? Does it comprise of anything more apart from the plug converter ? Thanx :)
SOURCE:
What are the best international calling cards/plans in India from India to the USA?
Dial91 is one of the best India Calling Card.It provides a very low rate, which serves all of your India Calling needs in clear quality to call India landline, mobile or anywhere else in this world. Dial91 allows you to recharge your pin automatically or by yourself on a range of $10 to $100. You can purchase it online securely.
Dial91 provides the finest PIN/PIN-less services and India Calling Cards for Indian Business Travlers and Non-Resident Indian on a low charge. Using Dial91 you can make calls to mutiple India Calling routes and to thousands of local contact numbers. Using it you would experience that the whole system is perfectly designed and managed for calling India.
More than featuring PIN free dialing it also gives advantage of speed dial, free sms and address book. You might have a query about setting up a PIN free dialing? Then you should follow the following steps:
Go to Best India Calling Card offers Call India now Just 1¢/minClick on 'User Login'Enter your 'User name' and 'Password'Click on 'Pin Free Dialing Setup'Enter the phone numbers for which you make calls regularly.
Dial91's customer service is available 24/7. Its routing work force is in USA and India, whereas its engineering and support department is always working on the ways to reduce the rates charged on making calls to India. So use Dial91 Card anytime you need to call India!
Aug 24, 2016 | Lands Phones
India 220watts how I cAn use brother cs6000i sewing machine in India
The only way I know is a 110/220 volt transformer.
They are available in any electronics supply house.
As I remember the motors in these machines are only two lead, and they put the motor in for the country it will be sold in.
Dual voltage motors have three or four leads (wires).
Jul 28, 2015 | Brother CS6000i Computerized Sewing...
My hp pavilion dm4 2180us will not turn on
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 17, 2012 | HP Pavilion dm4-2180us Entertainment PC -...
My adapter is not working
US house current is 110-120 Volts and 60 cycles. Adapter must have this type of power. India has 220 Volts and 50 cycles ( Hz). You need an adapter designed for Europe/ India
http://users.telenet.be/worldstandards/electricity.htm
Feb 28, 2010 | Panasonic Lands Phones
I too have the same problem
Well like you said, USA and India.
Did you check the power voltage from usa compaired to India? You might have just blown your system if you didn't pay attention to that.
It's not recommended to take outside of usa, but if you do, you should have bought a power converter/adapter.
Sep 07, 2009 | Nintendo Wii Console
Can i use an Xbox 360 bought in USA in India - given the voltage conversion required? would there be any seperate adaptor available for 220 volt usage in India
You can purchase a volt adapter (rather common in travel stores/airports) but over time the device's power-supply will wear out because of the frequency difference.
North America runs at 60hz
India runs at 50hz
Jun 30, 2009 | Microsoft Xbox 360 Console
Am planning to buy!!
those computers run from 85 to 264 VAC with the same input..only difference is the interface connector, which you can get in Canada..I do same thing with my US computer here in Euroland.
Oct 21, 2008 | HP Pavilion dv6000z 15.4" Notebook Laptop...
Open Questions:
Avast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uK
Oct 14, 2019 | Computers & Internet
See all HEWLETT-PACKARD HP Consumer Pavilion dm41063he Questions
HEWLETT-PACKARD HP Consumer Pavilion dm41063he Notebook Logo
109 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
