If you are using WEP or WPA security on your router try this:
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
But if your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings
(also known as "access control", "access list", or "network filter"
depending on your router model).
2. If the Mac address filter is
set to "enabled", then you must add the Wii's MAC address to the
"allowed" list. You can locate the Wii's MAC address from the "console
information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router.
1. go to our Wireless Router look up page.
2. Use the drop-down box to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many
issues can be solved by changing settings described in the "special
notes."
Lastly, Power cycle your router and modem by unplugging
them both from the wall. Wait a few minutes, and plug the modem back in.
Wait a couple of minutes for the modem to initialize, then turn on the
router. Try to connect the Wii console online and test for proper
response.
I hope the above solves your problem.
Good luck.
The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:
If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
