Brother DCP 130C All-In-One InkJet Printer Logo
Posted on Oct 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem: Black ink is missing a horizontally. Does print completely. Solution Tried: Cleaning the ink cart., as indicated for printing errors, but didn't fix the problem. Please suggest alternative solution...
Anonymous
Level 2:
Sergeant:
  • Expert 142 Answers
  • Posted on Oct 23, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
142
Questions
0
Helped
27039
Points
511
I suggest that you try a full cleaning again. The printer heads for these units are really prone to clogging. If that doesn't work, then that means that there is a defective resistor inside that head and you need to replace the head which is pretty costly almost near the cost of buying a new printer.
My printer prints pictures fine but when i print words it dont print black ink just colors why
Black printer ink in Canon Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Does not print black. ink tank indicates full and
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
My kodak 5300 black ink keep saying replace black ink cartridge and i have
Black printer ink in kodak Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Put black ink cartridge in and the printer does not realize it is in the black ink port (this question is for my son that is away at college) get an error message
Black printer ink in Lexmark Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
2answers
The black ink on my HP Photosmart 3310 printer does not print. All the colour cartridges print with no problems.
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
1helpful
Suddenly stopped printing in black though colour is OK.I've tried all the usual things!
the ink head is probably jammed with dry ink. wihen the head is jammed, a lot of ink will pool at the bottom right of the printer. clean that pool, and dab the black ink head with a damp paper towel, but do not rub. blow the ink head with a can of compressed air. run a nozzle cleaning, and nozzle check until the printer is printing better. the nozzle check prints out grid for each color. if the grid is complete the printer is fine. sometimes a few horizontal bars will be missing and cannot be cleaned.
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Norman Weimar
Norman Weimar
k24674
