How do I program the HP laserjet M1522nf fax? Somehow the fax function is NOT receiving. I can fax out by it is not working for incoming faxes. Thanks, Stephen
  • 7,733 Answers
Do a search at HP Support & Drivers
Posted on Oct 24, 2010
SOURCE:
I have a provlem with fax on the HP LASERJET M1522nf
I have problem with my MFP 1522nf Printer I cant recieve fax on incomming call it is quite dead while It is set in automatillay answer mode when I dial it dial and gives tone but while in comming call no rings no reply ring answer mode is 1 but quite I checked every way settings wires but cant understand can any one know about this and help me.
My email [email protected]
Thank you
Mar 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
How do i receive fax
Here is the link to HP Official Support site. You can download the User Manual for HP LASERJET M1522 NF MFP Printer. Go to Section 10- Fax (Page 69) for complete and step-by-step instruction for setting up fax.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | HP LaserJet M1522nf Multifunction Printer...
My HP LaserJet M1522nf printer will no longer 'boot up'. When turned on the display panel illuminates and then displays "Hewlett-Packard >>>>>" and then all...
Hello, a classic presentation of a failed formatter board, follow my link for a more detailed report and possible repair guidance... If you hurry I suggest HP should repair this under an extended warranty program.
M1522INFORMATION
Thanks and good luck Feb 3 11
Nov 10, 2010 | HP LaserJet M1522nf Multifunction Printer...
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
[email protected]
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Can I send a fax from my computer via the HP LaserJet M1522nf?
Yes you can send fax from computer.You need one dialup connection with Fax modem. then you need fax software. there are many software availble on the net . One is Mighty Fax. you can download it from the internet and many other you can search in google.
Sep 17, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Mar 25, 2009 | HP LaserJet 4 plus Printer
HP LaserJet M1522nf MFP No Fax detected
The book says
No fax detected
The product answered the incoming call but
did not detect that a fax machine was calling.
This could be really tricky. The missed faxes could be just random wrong number or recorded sales calls that are dialing you machine.
If you are sure they are fax machines calling then we get into phone line issues and that sort of thing. If you get static or noise on the line it can affect your machines ability to hear the other machine. I saw somewhere tha replceing the cord form the wall to the fax helped some people with a similar problem.
You can always try turning the machine off and unplugging it for awhile this is a common suggetion from HP for almost any product with a problem.
Hope this helps
Mar 12, 2009 | HP Office Equipment & Supplies
Open Questions:
Computers & Internet Logo
88 people viewed this question
Ekse
Alun Cox
