Question about KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator
The icemaker has stopped making ice. I have confirmed there is good water flow to the cold water dispensor - need next steps in troubleshooting if it is a water flow issue or harvester issue. Many thanks.
  • whiskywizard Oct 24, 2010
    Thank Bob. I'll pull it out.
    Guru:
  • 1,524 Answers
The unit uses a dual water valve. One side for ice the other for water. check the valve.
Posted on Oct 23, 2010
Testimonial: "Very helpful!"
  • 3 more comments
  • whiskywizard Oct 23, 2010
    To be clear, this fridge has the water dispenser inside the fridge and the ice maker is separate, down in the freezer. Can you describe where that valve is located, and how to access it? Thanks
  • Robert Moller
    Robert Moller Oct 24, 2010
    Back bottom right hand corner.
    Based on bobicehouse's advice, I pulled the fridge out and disassembled the stamped steel panel that secures the double water valve. Using the water dispenser wiring harness to jumper power to the ice supply valve, I confirmed the ice supply valve works fine.
    I think I need to replace the ice maker as a module. Should I just replace it, or is there further troubleshooting I can do on the ice maker itself?
  • Robert Moller
    This may help http://www.acmehowto.com/howto/appliance...
    That's what I needed. Thank you Bob.
SOURCE:
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
Icemaker not getting water
The water valve is a double valve and one side is for the water dispensor and the other side is for the ice maker. if you know the ice maker is cycle is completing the water valve could be bad. Also make sure the water fill tube is not frozen. if it is, the water valve is bad and the tube will need to be defrosted.
It is not common that a ice maker that cycles will not send the power to the water valve. It could happen but is not common.
Jan 14, 2010 | Refrigerators
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
It stopped making ice but cold water option works fine. No clogs visible. Changed cold setting to 7 from 5. Nothing worked. just took out water filter, but can't see how that was the problem.
Put the filter back in . Pour about 1/2 cup of water into icemaker . If it dumps , then replace the water inlet valve . If it doesn't dump and the ice stays in the icemaker , replace the icemaker . Also , make sure the coils are clean of dust etc... Reset the controls back to normal or you could create water freezing in door (dispensor) .
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
My icemaker is not working
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jun 30, 2008 | Frigidaire GLRS237ZA Side by Side...
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator Logo
210 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
