Question about Linksys Wireless-G WRT54G Router
I need to connect it to my PC I dont have the CD to be able to use my wireless laptop
  • Linksys Master
  • 7,733 Answers
Go to Lynksys Support and Services
Posted on Oct 24, 2010
2 Suggested Answers
SOURCE:
redhaze89
  • 854 Answers
SOURCE: can not connect netgear wireless to mini laptop
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 11, 2009
Cant connect my phone to laptop
Dont worry all you need to is follow the following steps :
1.turn on the bluetooth in your cellphone or if you are using a USB cable so insert the CD for the cellphone
2.install the software for the cellphone in your computer as for NOKIA its NOKIA PC SUITE
3.turn on the wireless in your computer or connect the USB cable
4.for bluetooth connection only(go to bluetooth devices)
select add a wireless device
5.select your device
6.go with the Addition process and close the window
FOR USB CABLE CONNECTION
connect your phone to the PC and start working
Thanks
Regards
Hamid
Jul 15, 2010 | Computers & Internet
I want to connect to a wireless router with my laptopbut dont seem to the wireless drivers.i have tried to connectwith virgin media modem and router .followed all instructions and when i remove ethernet...
Sir, try downloading the wireless driver from your laptop company's website. Or form the drivers cd/dvd they provided you. Then you can connect to any wireless capable modem/router from your laptop.
The ethernet cable provides the internet pulses into your laptop. If you remove it, your internet connection gets disconnected.
Jun 30, 2010 | Advent Netbook
I have a linksys wireless router that someone just gave me but i dont have the installation cd. Is there any other way to install it? I have tried hooking it up but i get nothing.
No need ti install cd for router
steps
1,connect router to isp provider connection
2,connect network cable from the laptop/pc to router
type ip address of the router on the computer browser
eg:192.168.1.1
username:admin
password: admin or admin12
configure the router by the help of isp provider
Nov 01, 2009 | Linksys WRT160N Wireless Router
X360 and PC connect - Laptop doesnt!
Looks like you may have WEP security on router and WAP on laptop - or vice versa. Change the laptop to match the router.
Oct 23, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
Sep 29, 2009 | NetGear DGN2000-100NAS Router
How to connect LG Arena to Acer Aspire One with Linux linpus?
You need your to connect your Aspire to a network on which there is a device that does have a CD drive. Share the CD drive with the network and you are home free.
That is how I get stuff onto my Aspire One.
As for connecting your cell phone to the device - sorry. I dont know how to do that.
If you need help with sharing your CD device or setting up a network, you can ask Windows how to do that. If you dont have a wireless router, you will need one. Oh yes, and a second computer. IF you dont have a second computer, borow one from a friend.
If you need more help ... Id like to give it a try.
a
Sep 27, 2009 | Acer Aspire One PC Notebook
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
ROUTER WORKING WITH INTERNET BUT NOT SHARING WITH MY LAPTOP AND I PUT THE CD AND IS A PROBLEM DONT LET ME CONFIGURE THE COMPUTER
you have ethernet plugged in right from mdem to router then your other pc plugged in #1
run the cd on the pc that has internet
make sure your wireless on laptop is showing in network connections
then right click and click enable if no option for enable then click reoair if not solved then you need to setup wireless account form network connections
let me know if this helped
Feb 02, 2009 | Computers & Internet
Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Oct 15, 2008 | Acer Aspire 3000 Notebook
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
