Question about Gateway Computers & Internet
We have no sound on newAOC24"monitor Number2436 Gateway tower Can you help ?Technician asked for manual ,cannot find it on line Sound is supposed to be in machinebut no success by trchnician, otherwise setup is great
  • Gateway Master
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 23, 2010
SOURCE:
HOW DO I CONNECT A GATEWAY LP2207 TO GET THE AUDIO TO WORK?
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
What type of pc tower is compatible with an older gateway monitor model fpd1750
Try typing in, "compatible PC towers for gateway model fpd1750" on Google.
Jun 13, 2014 | Gateway FPD 1750 17" Flat Panel LCD...
Ocasionally diagonal lines appear on the monitor or the whole pcu turn off by its self. When thie lines appear the only way to get going again is to manually hit the power button on the tower unit
Hello. Have you tried using this monitor on a different computer? This would help us understand if this is being caused by your computer/video card or the monitor itself is dying and needs to be replaced/fixed.
Jul 18, 2011 | Gateway FPD1760 17" LCD Monitor
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
I have a gateway gt5056 with no sound. tried other speakers, not the problem. How do i check/replace the sound board?
well take off the side panel of the tower you know the card you plug your speakers into? well there is 1 philips screw that holds it in place remove the screw and then gently rock the card back and forth while trying to lift it out now take the new card line it up and push downward it should seat itself all the way down then put the screw back where it came from and put back the wires for the speakers hope this helps if ya have any questions feel free to ask
Dec 07, 2009 | Gateway GT5056 PC Desktop
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
No sound for Hannspree HF199H 19" LCD
Kalungka,
you need a third lead to connect from your sound card line out to the line in on the monitor.
Regards
ElApe
Sep 26, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
