Question about Samsung HP-T5064 50 in. Plasma HDTV
No picture have sound hp t5064 - Samsung HP-T5064 50 in. Plasma HDTV
    New Friend:
I have a samsung hp-t5064 with sound and no picture. I purchased a service manual and went through the check list of solving the problem. It tells you to remove 4 plugs from the SMPS board (cn810, cn809, cn808, cn807) and you should get dc voltages at test pin (Vs 207VDC) and test pin (Va 63VDC). If you do not get these voltages at these two pins you should replace the SMPS borad. My question is when all plugs are unpluged I get Vs 0VDC and Va 63VDC but when I start plugging in the plugs one by one nothing changes as far as voltages until I plug in the CN807 Main board and the voltages are at normal Vs207VDC and Va 63VDC. I am asuming the SMPS board is bad. Would I be correct?
Posted on Dec 15, 2010
2 Suggested Answers
6ya staff
SOURCE:
Azrael SRL
  • 11800 Answers
SOURCE: I have a Samsung Plasma
I'm assuming that nothing appears on the screen, not even the menu.
In that what you can do depends entirely of the extent of the damage. If you're lucky it can be just a failed Y-sus board which is relatively cheap and easy to replace. If you're unlucky it's a complex failure, starting with the power source and it will be very hard to diagnose and fix. The only way to know which is to open the tv and test it by measuring the voltages on the power source and the Y-sus board - this should be done by you only if you have at least a basic experience in electronics. If you don't have it then leave that alone , unplug the tv from the wall and call a repairman - if you mess with it the only result will be to make the problem bigger and more expensive to fix.
Posted on Feb 06, 2011
No picture, no video
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 11, 2015 | Samsung HP-T5064 50 in. Plasma HDTV
What could cause this ?
It is not an adjustment of any kind but is a module inside the set having to do with the sweep of the picture information. Specifically the Sustainers
Jan 01, 2008 | Samsung HP-T5064 50 in. Plasma HDTV
I have a samsung hp-t5064 that show grainy picture with scanning horizontal lines. TV repairman came and looked around the back. Opened it up, replaced some boards, don't know which, I was not
You can also check for poor connections on ribbon cables etc.
Socketed Chips etc.
Modern TV's are more "Computer" than old fashioned TV. You could have memory problems, CPU or timing problems. Power supply problems.
Did the problem occur overnight. Like On/Off... or has it gradually gotten worse. All of these things can be clues. Does a slap on the back cause any glitches or changes to picture. If so then it could be an indicator of a physical problem like a poor connection.
Suggest getting a second tech's opinion before any replacement
Good Luck
Nov 27, 2014 | Samsung HP-T5064 50 in. Plasma HDTV
TV TURNS ON BUT DOESNT HAVE PICTURE?
check the wiring connections to the specific input you are using
is the device that broadcat the image active? reset this device
Apr 25, 2014 | Samsung HP-T5064 50 in. Plasma HDTV
My samsung plasma 50" model HP-T5064 cant turn on. what could be the problem?
Make sure all of the cables are very tight on it. The button may actually be faulty, believe it or not. This is common on the model you are speaking of. If the remote won't work either, it is most likely a short.
Oct 06, 2010 | Samsung HP-T5064 50 in. Plasma HDTV
Clicks wont come on like circuit breaker going on
Ur power board is dead,know how to solders?Check the power board for Capacitors puff up or burst open replaced these capacitors.Or buy refurbish power board on Shopjimmy.com,Ebay.com.
Jan 16, 2010 | Samsung HP-T5064 50 in. Plasma HDTV
No picture
It sounds like the backlight is out. If you can see a faint image that changes then this is the case. You either need to send in for repair or replace. It can if you are lucky be a connection. You can try removing the video cable and try another source or cable.
Jul 09, 2009 | Samsung HP-T5064 50 in. Plasma HDTV
Tengo un tv samsung hp-t5064 , no quiere encender solo hace el intento , suenan los rileys del power suply, pls necesito ayuda mi mails es este,, [email protected] byee
hola, chequeate los capacitores de la fuente de alimentacion es muy posible que esten reventados, solo destapas el televisor  con mucho cuidado, mira la fuente y veras de lo que te estoy hablando. si no tienes experiencia tecnica llama al tecnico.
buena suerte. [email protected]
May 19, 2009 | Samsung HP-T5064 50 in. Plasma HDTV
Samsung HP-T5064 50 in. Plasma HDTV Logo
1,156 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
