Question about ViewSonic VG900b 19" LCD Monitor
2yahoo.co.inhow to attach this to dvi desktop
    Brigadier General:
  • 10,406 Answers
Does your computer's video-card have a DVI-output socket?
Does your LCD monitor have a DVI-input socket?
If 'yes' to both, then you need a DVI-to-DVI cable.
Does your LCD monitor have a VGA-input socket?
If 'yes' to both, then you need a DVI-to-VGA adapter,
and a VGA-to-VGA cable.
Posted on Oct 23, 2010
SOURCE:
Can I attach a HDMI cable to an Old Samsung TV Model # HLN5065W1X/XAA
Gina, these are all the inputs on your TV
S-Video 4-pin DIN (2 sets) Back Composite RCA (2 sets) Back Component 3 RCAs Back Component (HDTV) 3 RCAs (2 sets) Back RGB 15-Pin Dsub Back Tuner Co-ax (2 sets) Back DVI Digital Input 24 pin DVI Back S-Video 4-pin DIN Front Composite RCA Front
You can not use HDMI cable with this set up.
Feb 22, 2016 | Samsung Televison & Video
How do i use this product attach to my acer aspire laptop
you didn't say what model Acer Aspire you have but if it has HDMI output you can use an adapter to DVI.
Apr 16, 2015 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
How can i exit analog power saving mode from lg flatron desktop
If possible, attach analog and DVI cable together from one single graphics card.
Just to test your monitor is due to old age or component failure.
Jun 04, 2014 | LG Flatron L1750S 17" LCD Monitor
No DVI INPUT no VGA INPUT
It sounds like the video card is defective if the computer boots, but the monitor saying that there is no device attached
Jan 24, 2013 | Acer Computers & Internet
After installing the mother board and checking all connections my computer will not turn on. I have windows7, is it possible that the power has been disabled from inside the progam?
desktop or laptop computer
does it recieve any power at all ie:lights
make sure cmos battery and ram modules are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
how did you check the leads ?
even something as small as a fauly fan and the fans electrical lead can cause this problem
hope this helps you
Oct 23, 2011 | Computers & Internet
Acer signal lost on the monitor.
Check to make sure the cable from the monitor is securely attached to your desktop.
Mar 05, 2011 | Computers & Internet
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
I want to switch it my monitor from HD15 Mode to DVI on my VGC RB52
Assuming you have not already upgraded the system, you will need to add a video card with DVI output to your computer. You need a PCI-e x16 card and to make sure to either upgrade your power supply or choose a card that will not exceed the power supply's capacity. The original Power supply provided 305W (max.).
The alternative is to simply attach a DVI to VGA converter and stick with the on-board VGA only output but send it through the DVI port on the monitor.
I hope this helps.
(you should pay attention to heat issues if you add a video card; I've generally found that ATI cards run a bit cooler than nVidia cards for the same generation/performance.)
Mar 02, 2010 | Sony VAIO PC Desktop
Trying to hook up my pc to my Sharp LC19sb24u flat screen not sure what cords I need
If the connection looks like:
you would need the corrisponding cable:
If your Sharp LC19sb24u has additional audio inputs they are the same as if hooking up your speakers on your computer.
If your Sharp LC19sb24u has a connection such as: (HDMI Connector)
You will need a DVI to HDMI cable:
6e38ef9.jpg DVI attaches to your computer and the HDMI end attaches to your Sharp LC19sb24u.
Hope this helps, if it does not - please write back and we can help you further.
Jul 22, 2008 | Sharp Computers & Internet
Open Questions:
See all ViewSonic VG900b 19" LCD Monitor Questions
ViewSonic VG900b 19" LCD Monitor Logo
115 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
