Question about HP Photosmart C5580 All-In-One InkJet Printer
I got hp deskjet f4272 printer all in one and when i printer a picture on premium photo paper it does nt print the whole image it cuts of the half image and leaves it blank on the other side
  • HP Master
  • 7,733 Answers
Try HERE.
Posted on Oct 24, 2010
6ya staff
SOURCE:
Why does printer only print half of the picture
Your paper size may be samller then the size of the image you are printing. Try changing the size of the image or size of paper to match.
Aug 12, 2014 | Sony Picture Station DPP-FP90 4x6 Photo...
How do i go about printing different size of photos? they are all different sizes.
There are two basic ways to change the print size of your photos/documents.
1. You can go to file/print or you can press cntrl + p on your keyboard. the print menu will come up. go to properties/features. when it opens, look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. other procedure is to right click on the photo/image and select print. a print wizard will pop up. it will ask you to chose size of images.
Good luck,
Ryan
Jun 11, 2011 | HP Deskjet D4160 InkJet Photo Printer
My Deskjet 970cxi printer is now using too much ink (which does not dry) when printing photos on premium photo paper. the results on ordinary paper are much better. How can I rectify this Ian
When you give a photo print, the print quality will be high.
To adjust this go to Printer properties.
1) Go to control panel
2) Open Printers and Faxes.
3) Right Click on Printers.
4) Select Printer Properties.
5) Select Printing Preferences, and choose quality of photo print to medium
Dec 03, 2010 | HP DeskJet 970cxi InkJet Printer
My 4x6 prints are not centered on paper
That printer can't print borderless on 4x6 photo paper, you should use A4 size paper, print and cut the pictures.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
How do I change the print size on my D4160 hp printer
There basically two approaches to changing the print size of your printer whether D4160 printer or any modern other particularly hp printer.
1. Go to file/print or simply do ctrl P on your keyboard. The print menu pops up. Go to properties/features. When the features tab opens look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. The other procedure is to simply right click on the image and select print. A print wizard pops up. It enables you to chose size of images and automatically fits them into 1 per page, 2 per page or 4 per page depending on how many images you selected in the first place. However this is meant specifically for images/photos.
3. Again you may decide to physically resize them in the application (Word, CorelDraw etc) you are working with before sending print.
Sep 03, 2009 | HP Deskjet D4160 InkJet Photo Printer
THE PRINTER WILL PRINT ON NORMAL PAPER BUT NOT ON kODAK PREMIUM P
Ok,, thanks again for the additional info. I had the same problem at one point with my HP photo printer, it seems the electronic eye that watches for the edge of the paper somehow can't see/focus on some of the high gloss papers.
How I tested it was simple. I roughed up(wrecking) one sheet and ran it through, it saw the page and printed. after that I tested with semi-gloss and it seems to work better.
Give that a try and let me know if that works.
Chris
May 27, 2009 | HP DeskJet 932c InkJet Printer
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hp deskjet d2360
Hi
Yes the HP Deskjet D2360 will print pics. If you want to print photo quality, make sure your ink cartridges are in good shape and obtain photo quality paper.
You can actually print pictures on almost all printer paper but if you want a good result, I would suggest you look online for inkjet photo A4 photo paper.
Paper can be obtained in a number of finishes. For example Glossy, Silk, Matt and so on. If you just want reasonable quality for a school project or something, then a good quality non photo paper may be good enough for you.
Paper also comes in different thickness or weights. This is determined by the paper's GSM. For example: 80gsm is normal photocopier paper. A good quality photo paper would be 140gsm or 160gsm. When looking for paper online you'll see the GSM shown. It really is your personal choice. There are heaps of suppliers on the internet. Amazon do a good range.
You can also set your printer for various levels of quality. A rule of thumb is, the bettter the quality, the more ink you will use.
If you want to find out more about your printer, visit http.www.hp.com then look for your particular model.
Hope this helps.
Jan 29, 2008 | HP Deskjet D2360 InkJet Printer
HP Photosmart C5580 All-In-One InkJet Printer Logo
139 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
