Question about Ruud UBHC Air Conditioner
Ruud out side unit
MY outside unit wont come on it just gives a buzzing noise what could be the problem
  • 1 more comment
  • HOVEW31 Jun 08, 2008
  • lwalton Jun 09, 2008
    My unit comes on but air doesnt blow.
  • PreissDog Jun 11, 2008
    I have the same problem but I don't see where there is a fuse outside.
  • 54 Answers
It sounds like you may have lost line voltage to the unit. What you hear is most likely the buzzing of the compressor relay which is energized by 24v from the indoor unit. Look at your condenser coil, are the aluminum fins clogged with debris? If so this is likely the cause of the tripped breaker and will need to be cleaned. Before you go to the trouble have someone go to your breaker panel and flip all the 220v DPST breakers off and back on while you watch and listen to the condenser to insure that the fan and compressor will come on line as soon as this is confirmed turn the breaker off and clean you condenser coil, the correct way to clean the condenser coil is to remove the disconnect plug at the unit or turn of the line voltage at the breaker, remove the top panel that supports the fan , flip it over being carefull that it's weight is supported in a way that wont stress the wireing harness to the fan motor. Spray the inside surface of the condenser coil with a heavy foaming cleaning solvent and let it have time to saturate the grime compacted between the fins then spray from the inside out and from the top down until the water runs free and clean from the inside thru the coil. Replace the top panel and allow time to insure that any water that might have gotten into the fan motor housing has evaporated, Then start it up if that was the original cause of the thrown breaker (very often is) then your in good shape and just saved a service call, Gratz!
Posted on Jun 08, 2008
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Ruud Problems
compressor is probably bad. disconnect it tape the wires off and start unit. if breaker doesnt trip it is the compressor.
Aug 17, 2008 | Ruud UAKA030 Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Buzzing on unit
Is the buzzing in the outdoor half of the system? If so
your possibilities are.
buzzing could be the contactor. In the control compartment on the side of the unit there is a small brown component that has wires to one side and the other . There are contacts in the center like points on a car. If the points are pulled in look for ants in between the contacts. Always secure power to the outdoor unit before touching anything inside. If the points are pulled in check your breaker to the outdoor unit. Turn the breaker off then back on. Breakers sometimes trip but look ok.
Buzzing could be thee coil to the contactor itself, sometimes with age the coil will breakdown and cause noise.
if you give me more information I can focas in closer to a solution
May 16, 2008 | Ruud UAKA030 Air Conditioner
Ruud UBHC Air Conditioner Logo
147 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
