Question about Ingenico eN-Touch 1000 Digital Pen
Stylus Pen Require Compatible with Ingenico En Touch 1000 Pad
Which Stylus Pen is Compatible with Ingenico En touch 1000 Pad
  • 3 Answers
Manufactur Part Number SEN351495LF
Posted on Aug 08, 2008
Stylus pen using on adobe photoshop
If it is a resistive touch screen you can use anything as a stylus. To test if it is resistive touch it with a non conductive material like something made of wood or wear a glove. If it doesn't work then it is a capacitive touch screen and then you just need to buy any capacitive stylus and yes it will work. Photoshop should work fine too.
Jul 04, 2013 | HP Pavilion TX2110US PC Notebook
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
INGENICO EN-TOUCH 1000 - NO POWER
Hi, just checking to see if you discover a solution to this problem.
I had a couple of these and I cannibalized a machine with a bad screen to get another working and once inside realized that there were pressure switches that required reseting.
Mar 21, 2009 | Ingenico eN-Touch 1000 (9171020210083)...
Going from one POS system to another
If you are having communication problems with the port on the computer then this can solve it. make sure your pos system is not running or any other background services that monitor the port. Then go into your device manager and go to the properties page for that com port (COM2 for example), hit the device settings tab and change the data bits setting to 7 rather than 8, if this number is different than 8 which is default, just remember what it was in case you need to revert the setting. good luck
Nov 04, 2008 | Ingenico eN-Touch 1000 Digital Pen
BLURRY SCREEN
This problem is easily repaired. The heat seal connector between the PCB and glass is defective. For repair information contact david@davandisplay.com
Aug 24, 2008 | Ingenico eN-Touch 1000 Digital Pen
Leapster with broken pen
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
Touch screen not working
Have you tried a new battery in the stylus? They require AAAA size batteries. The first time my pen went out I thought it was the computer not responding, but it turned out to be a dead stylus battery.
Mar 21, 2008 | Averatec C3500 Tablet PC
Pen writes in one spot, but image shows up 1/2 below.....
1. To calibrate the ENTouch 1000 power off the device.
2. Prior to restoring power touch the pen to the center of the screen and do not move it.
3. Power on the device. Leave pen in center of the screen and do not move it. If you move it the device will not enter calibration mode.
4. Allow device to boot. If you held the pen in place the EnTouch 1000 will enter calibration mode.
5. Follow the on screen instructions. Be very methodical and do not try to rush it...
Nov 20, 2007 | Ingenico eN-Touch 1000 Digital Pen
Dispaly on eN-Touch 1000 is getting blank
Check the power adapter, sometimes they get hot and they don't supply enough power to the pin pad. Also make sure that the power cable is not loose, twisted or broken, this can also contribute to the problem.
Oct 22, 2007 | Ingenico eN-Touch 1000 Digital Pen
Ingenico eN-Touch 1000 Digital Pen Logo
496 people viewed this question
Top Ingenico Computers & Internet Experts
David Payne
David Payne
richie46
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
