Question about Emerson iTone iC200 Clock Radio
How do i reset the clock alarm - Emerson iTone iC200 Clock Radio
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
Alarm clock time keeps resetting
Download the manual here: http://www.manualslib.com/manual/1056350/Ge-7-4809.html
Dec 08, 2013 | GE 7-4809 Clock Radio
Can not get the clock or alarm off the 24 hour clock!!! very annoying!!
  1. Try pressing the "MODE" button until the time setting flashes.
  2. Now press the "2" button (right under the screen) and simply advance the clock past 24:00 and the clock will enter 12 hour mode again.
  • Now the time and alarm will be in regular 12 hour time as well automatically.
  • If for some reason it is not then just reset the alarm by
  1. Pressing "MODE" until the alarm time and icon flashes on the screen.
  2. Press "1" to decrease and "2" to increase hours.
  3. Press "3" to decrease and "4" to increase
  4. Press "5" to select the alarm volume.
  5. Press ALM "OFF/ON" to activate/deactivate the alarm.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 25, 2011 | Sharper Image SI785 Clock Radio
We have a roberts cr 9977 chrono logic v radio alarm clock and we cant reset the alarm clock. What can we do
got a roberts alarm radio clock cr 9977 electric went off wont come back on what should i do .
Jan 23, 2011 | Kitchen Appliances - Others
I need a manual for the Timex T229B clock radio. I can't even figure out how to turn off the alarm. Please tell me how I can find one - preferably free. Thanks, Patty.
I can't find the Timex T229B on the Timex support site. However, the T228B may be similar. To turn off the alarm completely, there is a switch on the left side that must be set to Off. The switch is labeled Alarm on one side and Radio on the other. In between are 4 positions - from front to back, Radio, Buzz, Off and On. When in the Off position the alarm indicator symbol will not be lit at the top left of the display (it looks a bit like a bell). The dimmer switch is in front of this Alarm/Radio switch on this side of the clock.
To turn off the alarm and reset it for the next day, press the Alarm Set/Reset button to the right of the hour and minute buttons. The Snooze button is the large button to the left of the hour and minute buttons.
Timex alarm clock and clock radio manuals are available here: http://www.timexaudio.com/product_manuals.asp .
I hope this helps.
Dec 23, 2010 | Timex T229B Clock Radio
I have a radio Shack Atomic Wall Clock 63-1438 and the time didn't change on Oct 31, 2009. Should it automatically change of do I have to reset the clock?
Most atomic clocks simply receive the National Institute of Standards and Technology (NIST) time signal. They do not all allow for daylight savings time changes as not all areas use it.
You will have to adjust manually.
Nov 04, 2009 | SkyScan 86709 Atomic Wall Clock
Smartset cd alarm clock radio-no working alarms
I had this same problem. I removed the battery and then unplugged it for about a half an hour. When I plugged it back in, I had to reset the date, time, year, time zone and alarm times, but the alarms now work!!
Nov 09, 2008 | Emerson Smartset Clock Radio
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
Soundesign 316G Jukebox Alarm Clock-can't set alarm
Press the alarm reset ( on/off ) for a few seconds.
Same as you do to set the time
Feb 13, 2008 | Novelty Simpson Jukebox Alarm Clock Radio...
Emerson iTone iC200 Clock Radio Logo
47 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
