Question about LG 42LP1D 42 in. LCD HDTV
This function is not available now
Last night all of the sudden I am getting this flashing message right in the middle of my screen. It will do it for a few minutes, quit for a minute and then continue.
  • 3 more comments
  • Anonymous Aug 04, 2008
    Same problem, hold down 'ENTER" button for ever and it goes away. Must call service tech to get it fixed.
  • dapiced Jan 01, 2009
    just to let you know that i have the dawn same problem !!!!
    please if someone know the problem and the solution, send me a email at
    dapiced@videotron.ca
    thanks
    my lg model is : 47lg70
  • Anonymous Jan 29, 2009
    I have a 32lg2000 and this function is not available now keeps coming up - any fix-it???
  • samart3 Feb 14, 2009
    42LG70 Began turning itself on and then flashing "This function is not available now". LG tech support said no known issues on this model and advised turning it off for 5-10 minutes. Told them I had done that, but the issue returned within a day.
    Because the TV was purchased less than 30 days ago I'm bringing back to Best Buy - called and they will replace it. So out it goes...
    I was able to get into one of the menus when this was occurring and then the selector kept moving up - like the "up" command on the remote above enter.
    Regardless, I'm sending this one back, but will try another one of the same model.
  • aBcDZ4217 Apr 03, 2009
    I have the same issue. Unplugging from AC for a minute and plugging back in at least clears the message.
I think i can help you with your problem.Disconnect all cable componets from the tv everything but the tv power cord once this is done unplug the tv for 60 seconds plug the tv back in. take the tvs original remote take the bateries out once there out point the remote at the tv hold the power botton down for 30 seconds while still pointing at tv then. put bateries back into the remote and the msg should be gone.
Posted on Aug 09, 2009
  • john Dec 25, 2011
    The solution seems to work for awhile only to come back again. The comment about the PS3 gave me an idea that I'm working through. I use my PS3 HDMI cable with the adapter for my computer output. I'm trying a regular HDMI cable to see if it is any better. So far, so good.
Cameras flashing between infrared (night) and NO SIGNAL - 1 is off (4 total)
Sounds like you have a power supply problem in the DVR, get your installer to check it
Jul 30, 2014 | DMCOM Zmodo Pkd-dk4216-500gb Complete 4...
Replaced 20A fuse - now display blinks
Here is the parts page for your unit with an exploded view and parts list
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R-9H84B/0958/0123245/P0050209/00001 It is possible the switch is bad the look at part number 1-6 hope this helps.
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
Hi,i purchased a LG GM360 two weeks ago,and last night it keeps saying i hav "maximum limit of applications reached" when i go to open a message or play a video,i was wondering if you could help...
If you press the button in the middle at the bottom of your phone the screen will show a list of apps running (or some shortcuts ,if so click the blue arrow at the top right of the screen to get to your apps page) .
Then you can press one at a time to goto and shut them one by one or press 'end all' at the bottom right to close them all.
Nov 01, 2010 | LG Cell Phones
I was using nokia 5220 music expess last night. while playing music i was surfing the net with opera mini5.1 and opened three tabs. the phone suddenly hanged with a white screen. on restarting some...
It sounds like you overloaded the CPU which forced it to reboot. Try removing the battery unit from behind, leaving it for 5 minutes, then reinserting the battery unit and switching the phone on. Give it a minute to fully load, then try opening your contacts and messages. If there still seems to be problems, services is where you should go to and have it checked.
Aug 20, 2010 | Nokia Lands Phones
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Nov 30, 2009 | Philips 42PFL5332D 42 in. LCD Television
No Video or Audio on HDTV/No Vodeo on Standard TV
Don't worry , You did everything right . The problem is
the G.P.U. . It has de-solder it self from the main board.
The only reliable repair that will last is to have it
re-flowed back to the main board and properly
re-clamp that will fix 99.9% of most problem.
Permanently ,cost should be around 80.00
if you have any questions feel free to email me.
Rob
Sep 21, 2009 | Microsoft Xbox 360 Console
LG 42LP1D 42 in. LCD HDTV Logo
4,232 people viewed this question
Computer Repairing
Computer Repairing
