Question about HHP IT3800 Handheld
How do I remove the first character (a "[") that precedes my UPC value whenever I scan a UPC barcode with my IT3800LR barcode scanner?
SOURCE:
  • 4 Answers
SOURCE: I can't programmed my IT3800LR
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
The factory reset bar code is on printed page 4 of the PDF document.
Posted on Mar 06, 2008
  • 31 Answers
SOURCE: Program Symbol LS2208 scanner
Hello this requires advanced data formatting which you will have to scan some bar codes to program it. If you give me your email I can send the codes to you.
Posted on Jun 30, 2009
  • 38 Answers
SOURCE: Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Posted on Jan 06, 2010
  • 25 Answers
SOURCE: how do I remove an 'A' from a barcode
What format is the barcode?
You should be able to program the scanner to from a leading digit or specific digit. We did something very similar to this, but I don't remember if it was a Symbol or HHP scanner.
Manuals for this scanner. http://www.honeywellaidc.com/Site.aspx/na/en/support/technical_support/retired_products/retired/?product=251
Posted on Apr 14, 2010
  • 74 Answers
SOURCE: I need to strip the
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Posted on Feb 14, 2011
It scans 'k' at start with upc code
It sounds like the scanner has the Symbol Code ID character enabled and you are scanning a GS1-128 (formerly known as UCC/EAN 128) code. You can disable this by scanning the Symbol Code ID None barcode from Adobe page 211 of 460 (Chapter 12 page 3) of the LS9208 Product Reference Guide. https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/6083309a.pdf
Apr 18, 2014 | Zebra LS 9208 Omnidirectional Projection...
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
How do I disregard the last character on a UPC bar code?
In general you can create an Advanced Data Programming Rule which will say: If you scan an UPC barcode, please send only the first 11 characters of the barcode.
There are programming barcodes in the manual for the scanner or you can use the 123Scan2 application provided at support.symbol.com to create the rule and print out an config sheet.
Aug 26, 2010 | Symbol LS2208 Handheld
I would like 2 know the model number/name of a barcode reader , also want 2 convert the 12 digit to 13 digit reading
If you want a cheap but reliable scanner try the LS1203 by Motorola (formerly Symbol) with any Symbol scanner to convert a 12 digit UPC into a 13 digit number you scan the UPC-A Enable System Character Country Code from the appropriate Product Reference Guide. The guides can be found at: http://support.symbol.com/support/supportcentral/supportcentral.do?id=m1
Hint: When searching change the Document Type to Product Manuals before hitting enter or clicking Go to reduce the search results to relevant documents.
Jul 07, 2009 | Symbol Computers & Internet
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Mar 05, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
HHP IT3800 Handheld Logo
343 people viewed this question
Top HHP Computers & Internet Experts
Marvin
Marvin
Ekse
gggg
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
