Question about Refrigerators
My refrigerator (Amana side doors) runs too frequently almost no stop everyday except defrost heating.
    Guru:
  • 1,524 Answers
Designed to run 80% of the time.
Posted on Oct 23, 2010
6ya staff
SOURCE:
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
Top half of both fridge and freezer appears to have stopped working.
Your defrost heater or defrost thermostat may be bad. Test defrost heating element for continuity. If heater is good, replace the defrost thermostat. In most cases, replacing both is advisable.
Dec 17, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Fan doesnt stop in Amana side by side refrig.
The fan is supposed to spop while defrosting kindly check the timer contacts or wiring short
Jul 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
On an Amana ARS2661BS Unit does not cool on either side
Pull it away from the wall and remove the cover the covers the compressor. Unplug and tell me if the compressor is too hot to touch or if running or any signs of life. If not running and cool I want plug it back in, and open the fresh food door and and look for a hole in the control panel where you adjust temperatures. The opening is about the size of a pencil eraser. Sometimes this hole is covered by a plastic plug. Stick a small flathead screwdriver slowly clockwise until the compressor restarts. If this works the refrigerator needs a new defrost timer. Sometimes the defrost timer will stick in defrost and stop. Let me know, Thanks Sea Breeze
Jul 21, 2009 | Amana ARS2661BS Side by Side Refrigerator
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana side by side ars2365ac
That fan is most likely on trying to defrost that frozen coil. It sounds like you may need a thermostat, a coil cleaning, and hopefully the system is not low on charge, those are 99% of the causes for a freezer, or refrigerator to freeze, hope all works out.
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
