Question about PfaFF Sewing Machines
Our Pfaff 1222 won't sew a straight stitch. The repair person said everything else is perfect, but doesn't know how to solve the straight stitch problem. Than ks.
SOURCE:
kimbo322
  • 10 Answers
SOURCE: Pfaff 7570 Sewing Slow
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
Posted on May 04, 2008
  • 980 Answers
SOURCE: Manual for a PFAFF 1222 sewing
Try www.sewingonline.co.uk/instructions or www.sewing-machine-manuals.com and click on relics, don't be put off by the word relics
Posted on Nov 03, 2009
  • 70 Answers
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Posted on Feb 25, 2010
  • 1788 Answers
SOURCE: loose stitching on underside of
It is in your top threading, believe it or not. Sounds odd but it is. Try this, insert a new needle (flat side facing the rear of machine), totally rethread according to your manual or go to www.sewusa.com for a free threading diagram, make sure that your presser foot is up, now when you are totally threaded, with the presser foot still up, pull on the top thread, it should feed smoothly, put the presser foot down and pull the thread again, it should barely move. This should seat the thread in the tension discs. If that doesn't do it, I am afraid that you may need a repair shop. Good luck.
Posted on Jan 28, 2011
  • 89 Answers
SOURCE: 1222 Pfaff can not adjust
Will need more info to help you. Is the white dot on the zig-zag dial still at the top? If not you will NEED (no way around it) a zig-zag dial rebluild. Most pfaff repair shops do not know how to do this repair, will need to find a 1222 expert.
This is my gess with what you have told me.
Hope this helps
Posted on Mar 31, 2011
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
The decorative stitch mechanism on my pfaff 1222 does not work
since it's a pfaff, I suggest having the machine checked to
see if a part or gear has become damaged and needs to be replaced
or the stitch mechanism may need some type of adjustment.
Dec 14, 2012 | Sewing Machines
I have pfaff machine model # pfaff 230, problem is that machine cant get straight stitch, i dont have any operating manual , kindly advice how this problem solve, i shall be very thank ful to you if you...
Hello
It's just a fact that any machine that only does a straight stitch has a better straight stitch than any machine that will also zig zag. The more things they do, the less perfectly they'll do each one in most cases. A plain zig zag will have a better straight stitch than a machine that also does reverse-cycle stitches. The thing is that the more play they have to build into the needle area, the harder it is to keep it from moving slightly this way and that way when you don't want it to, like on a straight stitch.
You may also be having a combined problem when you're sewing very thick seams. If your entire presser foot is not perfectly flat on your item, it will not sew as well as if it were. This is even worse when you get to a junction of several seams, and your presser foot may be at an odd angle to get up and over the junction. You can use a Hump Jumper to help, or even a folded piece of something, but it's still not going to be as perfect as if you were on a completely flat surface. You can use a Sewing Hammer to pound things as flat as possible before stitching, which will help some. You may also get help with a different type of foot although it doesn't really sound like that's your problem.
If you have a control box, push the buttons so all the lights go off. Something is making the machine back-tack. I have seen the problem be a mechanical issue. In that case you would be better off taking it to the shop.
Jul 12, 2011 | Sewing Machines
Someone gave me a Life style Pfaff sewing machine and I don't have the manual. I would like to know how to use the rolled hem foot and need to purchase a pipping foot. A foot to make pipping, 1/4 -...
I would suggest you contact Pfaff firstly to see if you can obtain a manual, its always worth having the one for your machine. I presume you are in the USA? if yes, go to www.pfaffusa.com or ring toll free 1-800-446-2333 Monday-Friday 8:00a - 4:00p CST or email [email protected]
or go to www.pfaff.com then choose your own country then go to "contact us". and find the details.
Using a rolled hem foot is the same on all sewing machines, you are introducing the cut edge of the fabric into the front of the foot and it rolls the cut edge twice, as you seam over it. Its fiddly, you need a straight trimmed edge, and you have to keep the same amount going into the foot for it to work. You can either straight stitch or do a small zigzag over the fabric. Getting it started is the hardest bit because you need something through the foot to stitch on so it doesn't just get pulled into the hole on the needle plate.
try this link http://sewing.about.com/library/sewnews/library/aatech0803.htm for a bit more info on this, some machine makes sell a 2mm, 4mm or 6mm foot for different weights of fabric and finishes. You can buy accessories for your pfaff from www.sewingpartsonline.com or from Pfaff. Pfaff website even has free projects and a newsletter for customers.
Just put the foot on, lower the pressure foot onto the edge of the fabric, do a couple of straight stitches, then raise the pressure foot and pull the fabric back an inch, so you have something to hang onto at the back, then put 1/4 of fabric into the open part of the foot, hold it there, lower the pressure foot and start stitching, keep a bit of fabric turned in in front of the foot so you help it go into the foot and try to keep it a constant width, trial and error, you'll soon get the hang of it.
Piping can often be done with your zipper foot, you just want to encase the piping cord with a bias cut fabric strip and stitch as close to the edge of the cord as you can to hold it nice and tight. Then put the piping strip between two pieces of fabric and again stitch close to the cord so the first line of stitching doesn't show. Some machines, the zipper foot will have a guide so you can squeeze the cord up against the foot. Here is a link for piping techniques http://sewing.about.com/od/techniques/a/covercording.htm and covering cord http://sewing.about.com/od/techniques/ss/cordingpiping.htm
Just cut the bias strip width to suit your cord width, join the bias strips together if you want lots of length, then wrap fabric around the cord, right side out, put it under the zipper foot and stitch through the fabric as close to the cord as you can, on some machines you can adjust the needle position to get close but check your manual for help on this, you don't want to strike the foot, just sew up close to it.
I haven't done double piping, but I presume you would sew two layers of piping on top of each other?
I've got a old "Sewing Soft Furnishings" text book that I found at the op shop for $2, the images are daggy but the techniques don't change, most furnishing stuff is just taking measurements, adding seam allowances, and sewing straight seams, so the machine doesn't have to be fancy, or need lots of accessories, just know-how. What you do need is a strong machine to sew upholstery fabric, many domestic machines just won't handle heavy weight fabrics too well. Large sized needles 110 size will be important too.
I'd suggest you try one of Debbie's free pillow guides as a start http://sewing.about.com/lr/free_pillow_projects/271734/4/ , go for something without a zipper at first, and once you've made a couple of easy pillows, your confidence will grow.
Good luck with your Pfaff and enjoy your sewing.
May 20, 2011 | Sewing Machines
1222 Pfaff can not adjust to a large stitch
Hope this helps
Mar 31, 2011 | Sewing Machines
Feb 24, 2010 | Sewing Machines
Best,
Kim
Mar 18, 2008 | PfaFF Creative 7570
Pfaff 1222 belt
Hi - a few suggestions:
  1. May just need a good thorough service - generally a good idea to have it completely gone over - by an experienced Pfaff tech - every year or 2. Internal parts can dry out and simply get jammed.
  2. The timing could be off - again an experienced tech can take care of.
  3. The cam-stack (the part that actually makes your stitch formations) may have cracked. At the age of your machine, this isn't uncommon.
At the age of your machine, many other owners actually have it "rebuilt" by an authorized Pfaff service person. This model is one of those that's worth the investment compared to buying a new machine of the same caliber/quality.
If you are comfortable removing the top cover, you may be able to look at the internal parts to see if anything is broken. This will at least give you an idea of what may be happening.
Many authorized techs will not charge you to look at the machine and give you a quote. We'd suggest calling a few sewing machine stores in your area. Don't hesitate to ask friends for their recommendation of a good service person.
Hope this helps - please don't hesitate to respond if you need further info or clarification.
Happy sewing,
Kim & Linnette
Feb 25, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
172 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
