Question about Fujitsu Siemens AMILO Xi 1546 Notebook
The fan is not turning... the computer overheats every 5 to 10 minutes .... different colour dots appear on the screen and then it freezes and turns itself of... the bottom of the hardrive so so hot u cant even touch it.... i need a new fan... help please..
    Guru:
  • 689 Answers
Fans are really inexpensive so thats a plus however it shouldnt be doing this .the sft could be coruppted so replace fan and re-install OS for base configuration then you will know if your os is corrupted at least --good luck!
Davey Snake!
Posted on Oct 23, 2010
SOURCE:
Dell laptop periodic buzzing
Sounds like a bad bearing or dust accumulation in the CPU heat-sink fan. If the fan does not cool properly the CPU will overheat and shutdown or freeze the computer.
Jan 29, 2013 | Dell LATITUDE Computers & Internet
Lenove z560 freezes when at rest
I think that it could be video card overheat try to remove dust from the vga cooler and system fan or upgrade it
but if you can give more information about what you mean by "freeze?
if it's the screen and all fan still turn it's probably an overheat
Oct 27, 2012 | Lenovo IdeaPad Z560 Laptop Computer -...
I am running Wxp on my Acer L100. After about 15
first things first pls check if the cpu fan is seated properly.
if not pls try to reseat the cpu fan, but before doing it put thermal paste on top of the cpu to haver a better contact on the cpu
if the fan is seated properly check the rpm of the fan on bios mode see if the rpm of the fan is fast enough.. if not then there's the problem.
this things only happens if the cooling system of your processor is malfunctioning. Your built in hardware monitor tends to turn of the computer to prevent further damage,,
Jan 11, 2010 | Acer Aspire L100 PC Desktop
Green flashing pixels on all dark colours on my computer screen? they NEVER appear on light colours, just darker colours esp black, they move to fit whatever i have up, they tend to make straight lines or...
My suggestion would be to test your computer using a different monitor. You have to find out whether it is your monitor that is bad or your computer. If you use a different monitor and everything looks fine and you see no dots then you know the computer is fine and it's the monitor that is bad. But if the screen still show dots and lines even with different monitor then your computers video card has gone bad and needs replaced. I would not try to repair the monitor that can be dangerous.
Good Luck
Proteus
Nov 14, 2009 | Computers & Internet
My xbox freezes and lines/dots apear on the screen
The graphics processor, and second graphics chip both require a reflow. A special BGA reflow 'heat' machine is required.
FixMyConsole
May 09, 2009 | Microsoft Xbox 360 Console
USB PORT NOT FUNCTIONING
does your machine make it to the windows login screen, or does it fail before.
I think you haven't installed you CPU correctly, or maybe did not put heat sink compund evenly on the heat sink, and that causes the CPU to overheat and freeze.
Mar 23, 2009 | Mercury P4VM800M7 Motherboard
Computer freezes constantly - has to be hard rebooted
HI it can be true if the fan stops processor overheat to prevent overheat. it should work all the time (when your pc is on ;))
Aug 15, 2008 | IBM ThinkPad T30 2366 Notebook
Screen patch
Sometimes lcds will turn a yellow/brown/redish colour if they overheat. normally this will not cause long term damage to the screen but it is not good for it, try letting the monitor cool then using commpressed air to get rid of dust or attach a small fan to see if it helps. This may not fix the problem but should confirm if thats what it is.
Oct 30, 2006 | Samsung 997DF 19" CRT Monitor
Fujitsu Siemens AMILO Xi 1546 Notebook Logo
241 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
