Question about Frigidaire AEQ6000ES Electric Dryer
Frigidaire Affinity dryer, AEQ6000es2, has quit heating. Parts manual makes it look like the heating element is on a pan at the back of the drum. How does one replace the element?
6ya staff
SOURCE:
dragonsthatk
albert getty
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
Donni Steen
  • 687 Answers
SOURCE: Trying to remove drum and how to check heating
You don't have to remove the drum to get to the heating element. Remove the cover at the bottom of the dryer, it should be on the right at the bottom.
Posted on Apr 11, 2009
James Chandler
  • 686 Answers
SOURCE: How do you change the heating element on a frigidaire AEQ6000ES2?
WITHOUT THE MODEL NUMBER THIS WILL BE AN EDUCATED GUESS PRY THE TOP UP AT THE EDGES IN FRONT BETWEEN THE TOP AND FRONT PANEL. THEN INSIDE THE FRONT PANEL WILL BE 2 SCREWS HOLDING THE FRONT TO THE CABINET THEY MAY BE 3-4 INCHES DOWN ON BOTH SIDES UNDO DOOR SWITCH WIRES AND RAISE UP FRONT AND REMOVE. NEXT REMOVE THE THREE SCREWS IN THE MIDDLE OF THE DRUM ON THE INSIDE. UNDO BELT OF COURSE AND REMEMBER HOW IT IS ON. AFTER 3 SCREW REMOVAL PULL DRUM OUT AND THERE SHOULD BE ABLE TO SEE HEAT ELEMENT. WHEN INSTALLING NEW ONE FOLLOW DIRECTIONS TO THE LETTER IT MATTERS. GOOD LUCK TO YOU.
Posted on Apr 12, 2009
Michael Childers
  • 240 Answers
SOURCE: frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Posted on Jul 04, 2009
Anonymous
  • 52 Answers
SOURCE: Our Frigidaire dryer quit heating-up.
its on the inside of dryer in the back behind the drum.
Posted on Nov 07, 2009
My dryer (Frigidaire Affinity)just stopped working as if the power shut off.. I have checked the breaker, it's fine. it stopped in the middle of a drying cycle. I'm thinking the control panel went out
http://www.appliancepartspros.com/repair-help/frigidaire-dryer-aeq6000es2-repair/aeq6000es2-wont-start.html
Take a look at this web page/video. Your problem may be that the thermal limiter switch blew (which is not that easy to replace) .... compared to something in the control panel going out. Had you been doing a lot of heavy dryer loads before the unit died .. or a lot of lint built up? A blown limiter switch in some dryers will be as if you unplugged it (nothing goes on) ... but some dryers will still turn the drum but not heat. I am not sure about your unit.
The limiter switch is a safety device so your dryer does not overheat .... so if the switch did blow try to understand WHY .... or it may just blow again.
Good luck...
Jan 02, 2018 | Dryers
The belt is broken i have a new one i need to know how to get inside the dryer
Hi Cyndy s
Go to the following webpage and watch the video on how to dissassemble your Fridgidaire Affinity Dryer this is for the front slide replacement but you will remove the drum and you will see where the belt goes.
http://www.youtube.com/watch?v=yIPnnUqJ6Ds
For parts and a schematic of your dryer.
http://www.appliancepartspros.com/parts-for-frigidaire-aeq6000es2.html
If the belt is broken and you don't know how to route the belt check out the following picture
Please rate me
Bud
Oct 25, 2012 | Frigidaire Dryers
Heating element quit working on my frigidaire affinity dryer
If the unit still works, it just does not dry, please have a professional diagnose the heating element and the blower assembly. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Sep 19, 2012 | Frigidaire Affinity AEQ6000WH Dryer
Model LEQ6000ES Affinity Frigidaire electric dyer purchased 5-29-06: tumbles but won't heat. Cleaned all air ducts and lint trap and still won't heat. Error codes not obvious. What else can we check?
you will need to check the main power and make sure there is 220 volts at the termianl block if that is goor then you will need to check the heating element an all thermal fuses.
remove the small panel in the back of the dryer so you can get the belt loose.
then remove the lid.Take out the four screws that hold the control panel in place.
then remove the screws that hold the front panel on and then remove the drum lift up on the back of the drum to get it loos e from the carrier bearing holder thenyou can get to the heating element and thermal fuse on the back wall of the dryer and the side wall of the heating element can.
Jan 08, 2011 | Frigidaire Electric Dryer
Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Jul 19, 2010 | Frigidaire Dryers
My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 26, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity dryer problem
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Dryers Logo
636 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
