Question about Brother HL 1230 Laser Printer
Need instal hardware to my computer to use printer
  • Brother Master
  • 7,733 Answers
    New Friend:
  • 98 Answers
Posted on Nov 02, 2010
SOURCE:
Izaakzakei cant get my printer connected to my laptop i have downloaded the driver but its still not working
You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control panel...click on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then next...you computer should install the hardware for you printer.
After installed, restart again...to see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
Sep 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I need to install my HPOfficejet J6413 All-in-One Printer/Scanner/Fax
YOU NEED TO INSTALL YOUR SOFTWARE FIRST...SO INSERT YOUR DISK...PLEASE MAKE SURE YOUR PRINTER IS NOT HOOKED UP TO YOUR COMPUTER YET...CLICK ON START...GO TO CONTROL PANEL...GO TO INSTALL NEW SOFTWARE.
(NOTE) SOFTWARE HAS TO BE INSTALLED BEFORE HARDWARE
AFTER SOFTWARE IS INSTALLED...YOU WILL WANT TO DO A RESTART...UPON RESTART...HOOK YOUR PRINTER UP TO ANY USB PORT...AGAIN... GO TO ...START...CONTROL PANEL...TYPE IN PRINTERS...GO TO INSTALL NEW PRINTER.
YOU'LL NEED TO DO ANOTHER RESTART...SO TOO MAKE SURE YOUR COMPUTER DETECTS THE NEW SOFTWARE AND HARDWARE. YOU CAN ALSO GO TO...PRINTERS...(FROM YOUR START...TYPE IN PRINTERS...SEE IF THIS PRINTER IS THERE? IF THERE, CLICK ON IT...GO TO PROPERTIES...DO A TEST PRINT!
NEED FURTHER ADDITIONAL HELP...PLEASE DON'T HESITATE TO CONTACT ME!
HAPPY PRINTING!
MARTIE
Sep 06, 2011 | HP Computers & Internet
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
How to install versajette M400 printer
To install your printer, connect the printer to the computer or laptop usint the cable that links it up.
The computer would see it as a new hardware, you can install it from the bar that shows up from the tab side, or you can also go to the computers control panel, select add new hardware, then a list of new hardware found will appear, then you select the versajette m400 printer, and install the drivers.
After doing this, you can now start printing with your printer.
Take care
Jul 10, 2010 | G7 Productivity Systems VersaJette M400...
Trouble shoot a printer
When your computer got repaired, the operating system probably is reinstalled on the PC. In that case the driver for the printer is not on the
system any more.
When you did already connect the printer before installing the printer's driver:
1. First remove the printer in the hardware manager:
Right click My Computer, select Properties > Hardware > Hardware Manager > Printers: right click the printer and remove the device.
2. Install the driver for the HP F380 from the disk that came with the printer or go to the support site for the software & driver download:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=1128296&lc=en&jumpid=reg_R1002_USEN
Select the software & drivers and next select your operating system for the correct download. After the download of the Full Feature and Drivers, run this software on the computer.
Connect the printer after the installation has completed or when during installation the software asks to do so.
Need more help ? Just post a comment.
Jan 06, 2010 | HP DeskJet F380 All-In-One Printer
How do i install
First, connect your printer to the power and to the computer with the USB cable. As soon as you connect the USB cable, the computer will ask you to install the hardware that is had found. Insert the printer's drivers CD and follow the instructions. Good luck
Dec 31, 2009 | HP DeskJet 3930 InkJet Printer
Can u brief me about drivers
Computer drivers are software programs. It helps a computer identify and run the hardware installed in it. For Example, without drivers the computer will not be able to distinguish between a sound card and a modem. Most devices on the computer need drivers to run. Computer accessories, such as printers, scanners and digital cameras also need drivers to function. All computer hardware and accessories that is purchased comes with drivers either in a floppy or a CD. The computer automatically loads the drivers when inserted in the drives. Drivers can also be downloaded from manufacturer's websites. You can download the most recent or updated drivers for a hardware.
Jul 11, 2009 | Computers & Internet
Lexmark 1240 printer need to install without installation cd
try the lex mark website..in the search box type model number if ur printer...select appropriate operating system and download drivers
Feb 10, 2009 | Lexmark X1240 All-In-One InkJet Printer
I am unable to load Printer Drivers on my XP computer. The printer is a bizhub C353 Series... I have the CD and I also tried the driver download off the internet. I have installed this on other computers...
ok i give u a short and easy answer
download a hardware software that atomically check your all computer hardware and download all hardware drivers atomically that u need to install.
download from:
http://www.download3k.com/DownloadLink1-DriverMax.html
http://innofiles.com/soft/dmx/drivermax.exe
Oct 17, 2008 | Computers & Internet
Trouble with installing software for PCI FLASH Memory Dell All-in-one
First uninstall the Lexmark and unplug it from your system. Next, do a SHUT DOWN. Turn on your system, load the CD, go through the installation process, then plug in your Lexmark.
Jul 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Brother HL 1230 Laser Printer Logo
80 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
