Question about Pioneer Car Audio & Video
Settings in car radio
I believe there are several settings that can be achieved on this in-car radio that can be carried out without the unit being switched on. Can you please let me know what these are?
Thanks
Allan Smith
  • AllanJ Jun 14, 2008
    Maybe the make/model of the car radio wasn't shown in my question. I have a Pioneer DEH p6300r and I believe there are some options that can be set by pressing a combination of buttons. An example of these options is changing the appearance of the 'entertainment'. I.e these options can be set without pressing the Source button first to switch on the radio.
    Hope this makes it clearer.
    Thanks
    Allan
    Scholar:
  • 71 Answers
Bewildered on this one....
Sumthin
Posted on Jun 11, 2008
I have a couple of questions regarding my jl 500/1. the first question: i just transferred my amp/subs (subs are JL W3s) to a new vehicle, and the place i had install it switched the "high/low"...
ok..well theres a lot of question in there, lemme take a shot at it.
the hi/low switch explained: the hi/low switch tells the amp what signal voltage is being delivered to the amp...hi-power (4-15volts) or low-power(micro-volts). Your aftermarket head unit had what are called pre-outs (or preAmp outs) meaning the source signal (your music) is not amplified before being delivered to the amplifier...sooo...your amplifier setting for your aftermarket radio would be 'low' to tell the amp that the music source being sent to it is low-voltage.
Typically a manufacturers radio will not have pre-outs, they will be amplified by the radios internal amp to anywhere from 4volts on up, and you need to tell your jl audio amp that the source music being supplied is 'hi' voltage.
soo...of course...if you are sending 10volts to the amplifier and tell it that your sending micro-volts (low setting) your amp will over-amplify the signal and thus the overwhelming bass you experienced.
May 14, 2011 | Jl Audio 500/1 Car Audio Amplifier
Power wires are 3? other then red & block wires what is next conector for?
You have 3 sets of wire connecting to the amp (besides the rca connection), Red is power from the battery, Black is the round wire (shorter the better), lastly Blue is the remote turn on wire. Without the remote turn on, your amp will not power up regardless of the power from the battery.
RCA connectors are for your audio, it carries the noise signal to your amp from the head unit...
Mar 21, 2011 | Phoenix Gold XS2300 Car Audio Amplifier
No radio signalcar on car radio player
there is a micro switch inside the player than turns off the radio when the cassette is being played, this switch fails and locks out the radio, this defective switch causes the radio to not switch switch back on when the cassette is removed, u do not mention the make model or year so that is about as much as i can give you right now, but in most cases if this is an older car it is best to try find another used radio on EBAY, if it is an aftermarket unit just replace it, the repair cost in most can exceed what the cost of a replacement is.
Oct 24, 2009 | Car Audio & Video
Blaupunkt 520, 100% full volume on start up
With me. I pressed the + volume button once from 13 to 14 and it went all the way to 30 ( highest volume) and wont go back down. it also wont let me go to the radio now
Apr 04, 2009 | Blaupunkt PCA250 Car Audio Amplifier
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Sony XM-1652Z
What head unit do you have?
Is there a dedicated subwoofer output?
If not, have you switched the rear output to sub output?
Is the amplifier set to LPF (low pass filter), and the gain turned up?
Many things can be wrong, but the fact that there is anything coming out of the subs is a good thing.
Start at the beginning - Head unit, then check amplifier gain/crossover setting.
If you are using a hi level adapter on factory radio, is the Bass on the radio up? is the output gain on the convertor up?
Jan 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Inconsistant Switching of Alpine MRA-F350 Amp
try and unplug the audiovox unit and check if problems still exist. and what swithes on what unit are you talking about? this kind of sounds like a wiring problem.
Nov 21, 2008 | Alpine MRA-F350 Car Audio Amplifier
No radio sound from my IVA-D310E
neither of those units use fibre optic cables! but it sounds like you puled out the antenna wire behind the head unit. if you try and search radio stations without the manual tune on and it keeps changing frequency on it and never stops then its the antenna plug.
Nov 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Unlock code
You need the manufacturer to unlock it. Codes are user set. There is no magic number to unlock units. It is an operation that the manufacturers do.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jul 07, 2008 | Car Audio & Video
My back speakers wont produce any sound
OK I believe there is a small indented "Reset Button" around somewhere on the back of the unit, With the unit powered ON, & using a small diameter implement, straightened paper clip etc, press IN the button and this should "Reset" ya unit. This may indeed fix all your problems as the Unit "Reads" the speakers at turn on.
Aug 08, 2007 | Kenwood KAC-8403 Car Audio Amplifier
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
