Question about 5900 SST 2-Way Security System / Remote Start System with Responder S
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
  • Viper Master
  • 625 Answers
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Posted on Oct 25, 2010
SOURCE:
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Turn off sleep timer doesn't allow time presets
Ahrin, have you tried going back to where you purchased it? You don't need to take the unit, just go back to the store and have someone demonstrate how to operate it, they may even write the instructions for you if you don't have the owner's manual
Nov 07, 2013 | Fujitsu Heating & Cooling
I changed the motor and transmission from one to the other .I went from and automatic to a 5 speed manual changed motor harness now the car will not start turn key and nothing new battiery can you give me...
If you swapped out the auto for a manual trans the car might have a neutral start safety switch preventing the starter from engaging. This would not be something you would have on a manual transmission. Instead the manual would have the Clutch Safety switch which will only allow the starter to engage if the clutch is pressed in. On an automatic it won't allow the engine to turn over unless it's in Park or Neutral. I would locate the plug for the neutral start safety switch for the old automatic transmission and bypass it.
Nov 24, 2012 | 1993 Geo Prizm
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Viper 5301 LE 2 way remote starter system installed in a manual transmission. When I set my starter everything seems to be functioning normally. Once I get out of the car and hit the lock button...
It sounds like the turbo timer mode is active. In this procedure, the MTS remote starter is active, it's just that once set (after locking the vehicle) the vehicle will run the preset time(1,3,5 or 10 minutes) before shutting down. The MTS remote starter feature should still operate with the turbo timer mode.
Feb 08, 2011 | 5301 LE 2 Way Car Remote Starter System
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
5900 SST 2-Way Security System / Remote Start System with Responder S Logo
921 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
garyg7133
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
