Question about Kodak Easyshare CD82 Digital Camera
Can't get my camera off interal memory have new sd card?
    New Friend:
My camera says memory card protected when i turn it on. it says to reset switch on memory card, but then when you put it back in the camera, it switches back. it wont let me do anything with it.
Posted on Oct 23, 2010
SOURCE:
What does back-up to sd card mean?
the camera has internal memory and also will have the option for external memory. If you have a sd memory card in the camera you can backup the internal memory to the sd card.
Then you can remove the sd card and put in a new sd card and you now have an sd card with your precious photo memory's copied from the camera internal memory. You may have a camera that allows two sd cards one for the photos and one to back up the photos. If you had your camera stolen or lost you would lose all the photos on the camera but with a backup sd card you still have the photo files. Also a p.c with a card reader device could read the files on the sd card and you could copy them into a cloud storage on the net or onto a network storage device or onto a usb portable drive with 2 terrabyte capacity .
https://en.wikipedia.org/wiki/Secure_Digital
Jan 29, 2016 | Cameras
What is the maximum size sd card (Gigabites)?
speed class choices.
about compatibility with host devices before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
  • sdxc memory cards must only be used with sdxc devices.
  • sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
  • sdhc memory cards can be used with sdhc devices and sdxc devices.
  • sdhc devices can use both sd memory cards and sdhc memory cards.
  • sd devices can only use sd memory cards.
http://www.tomshardware.com/charts/memory-cards,39.html
the link above has several chart on sd cards.
Jan 20, 2015 | Cameras
When i turn on my camera it says Meomory card unusable insert new memory card
Try formating the memory card using the camera's Menu - select format memory card.
Feb 27, 2013 | Kodak EasyShare Z710 Digital Camera
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Feb 08, 2010 | Kodak Easyshare C813 Digital Camera
I put a new memory card in our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 1 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.
1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
Unreconized file format and also says interal memory full
Internal memory is full as you have been saving pictures there rather than your card. Have you checked those are not your missing photos?
Get a new sd card for your camera-I keep 3 cards for mine so that I don't need to delete anything for ages. I back up all photos to pc. The photos on your internal memory can be copied onto your new sd card when you insert it. When you are certain they are on the card AND backed up on the pc then you can delete them from the internal memory.Try mrnu>image storage. On your internal memory there will be an option to copy the photos to a card when you have one in your camera. Do check the internal memory-it is full of pictures-they may be the ones you want!
Jun 16, 2009 | Kodak Easyshare C813 Digital Camera
Memory SD full
Can you put the SD card in an external card reader and see any files? Did you format the sd cards in the camera? You should never format the cameras sd card with a pc.
Apr 14, 2017 | Vivitar ViviCam 3746 Digital Camera
Kodak Easyshare CD82 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
