Question about Maestro Lutron Dimmer 1000 Watts Ma-1000-wh
Rocker switch works, FASS OK also, but tap switch is broken. can I fix it or does it have to be replaced?
The electrical devices that fit into a wall box are not repairable. This is true for dimmers, switches timers and receptacles.
Posted on Oct 24, 2010
SOURCE:
How can I replace broken switch?
The most practical repair is to replace the complete shredder.
Mar 14, 2016 | Office Equipment & Supplies
Ok so ik I'm posting allot haha but does anyone know where or how to adjust lifters just found out mine r just now needed adjustment in near mount Vernon WA or a price at least haha
In engines with rocker arm valve systems, the procedure I'm familiar with is to remove a rocker arm cover, and (one at a time!) while the engine is running, slowly back off the rocker arm retainer nut or bolt just until you hear the lifter tapping, then tighten it a quarter turn. If you can identify a lifter that is already tapping, tighten its rocker arm slowly until it stops tapping, then adjust it. Do not over-tighten! This can damage the engine.
Listen carefully to how the engine sounds; if it starts to stumble when you tighten a loose rocker arm, you've gone too far. If you cannot get the engine to run well without tapping, you may have too much wear in the valve train and may be due for a head overhaul, or you don't have adequate oil pressure in the lifters in question.
Repeat until all rocker arms are done. Replace the rocker arm cover using a new gasket, then (in a V-engine), repeat the procedure on the other side of the engine.
Wearing safety goggles, or better yet, a transparent face shield, is strongly recommended. Sometimes oil will squirt out a considerable distance from the lifter side of the rocker arm during adjustment, and the direction is not readily predictable.
Apr 03, 2015 | Cars & Trucks
Power Lock Unlock Rocker Switch
Hi E,with key OFF, try spraying a little ELECTRIC CONTACT CLEANER from CRC or Radio Shack into space between switch & panel on driver's side,cycle switch back & forth 10 or 12 times.driver's side switch 'overrides' others ,if cleaner dosen't work,replace it first. Good Luck
Oct 18, 2014 | Cars & Trucks
What do i do for tapping lifter
If your rocker arms are adjustable you can adjust that rocker arm by tighten it up a little at a time until tapping stops but,if the rocker arms are not adjustable or have a net lash then you will need to replace the lifter.
Jul 20, 2012 | 1999 Buick Century
Stuck Zoom Function On Nikon COOLPIX L20 Digital Camera
U obviously broke more that just the lcd screen. Your lens assembly is now fubar so you will have to pay the piper to fix it. Or just get a new camera.
Aug 28, 2017 | Nikon COOLPIX L20 Digital Camera
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Lower paper tray shows open but is closed
ok lets troubleshoot... lets say the issue is tray 4...
try switching tray 3 with tray 4... if error moved to 3 then something is broken on tray 3... examine it... compare it to tray 3 and find whats missing... if possible fix... if not replace...
if issue did not move then get a flash light and look deep into machine... see if anything is obstructing... could be as simple as a piece of paper... also make sure that the sensor arm isn't stuck or broken... bad sensors can cause this issue...
which leads to my next suggestion.... most trays have a rocker sensor somewhere that tells the copier the tray is closed... if both suggestions previously made did not work then find this rocker arm and trigger it... if it does not work when pushed in all the way then the sensor is bad...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 31, 2009 | Minolta DiALTA Di350 Laser Printer
Maestro Lutron  Dimmer 1000 Watts Ma-1000-wh Logo
157 people viewed this question
Top Maestro Electrical Supplies Experts
jdthefixer
sherlywang
sherlywang
Abhishek Bhatia
Abhishek Bhatia
Level 1 Expert
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
