Question about Amana ABB1927DE Bottom Freezer Refrigerator
Continuall running and not keeping temperature
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
My vestfrost refrigerator constaly stays running why is that
Refrigerators need to maintain a temperature between about 35 deg F and 40 deg F. If that temp cannot be reached it will keep running. An older Refrigerator would probably need to have the area under the front of the Refrigerator vacuumed out to remove all the dust.
A newer Refrigerator will not need that. Then it would be a thermostat problem.
Hope this helps.
Jan 27, 2015 | Refrigerators
Freezer keeps running
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Refrigerators
Why does the engine fan NOT turn off on my 2002 Jaguar S Type 4.0 liter? It runs for several minutes after turning the car off and will come on while driving. I just replaced the sensor and it is still...
It would not be abnormal, so long as the fan does not come on when you switch on from cold. The fan's job is to draw air through the radiator to cool the contained liquid to a suitable working temperature. The fans sensor is activated by the temperature of the coolant. If this is a problem which worries you, try driving as gently and slowly as possible for the last mile or two of your journey. If things are normal the fan should not run on switch-off as that 'trick' will have allowed the coolant to get below the fan-kick-in temperature before you stop the engine. If your vehicle has a temperature gauge use the rteading as an indication.
http://wiki.answers.com/Q/Should_the_radiator_fan_run_after_the_engine_is_turned_off
May 09, 2011 | 2002 Jaguar S-Type
ViP722k receiver, continuall freezes and restarts
Hi Mike Houston of DISH Network customer service here.When the 722k freezes and restarts on and off, the receiver may be in Bootrecovery, this process can go from 45 minutes to 4 hours. If after 4 hours itstill is going on and off and with the steps you have done we would need totake a deeper look and go through the menus of the receiver.
May 09, 2010 | Televison & Video
Diagram of where the small clear hose goes on washing machine
The tube should be connected to the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 24, 2009 | Kenmore Washing Machines
Dishwasher keeps running in wash cycle
I lifted this off the tech sheet for your dishwasher, it explains your problem of long wash times.
Heater or temperature
sensor problem:
■ Open connection or
component in heater or
temperature sensor
circuit(s).
■ Open in heater or faulty
temperature sensor.
■ Faulty heater drive
circuit or temperature
sensor input on control
Jan 19, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Question on temperature range
Most dehumidifiers run between 42 degrees and up. If you need one for lower temperatures you can buy special ones. If you have cold temperatures in your location the air is usually dryer in the winter so the dehumidifier is not really neaded during that season. The average humidity setting you would want to run it at is 60 Percent. It will keep your basement from becomming damp and also keep it from running nonstop. Good luck and if you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Jun 04, 2008 | Kenmore 54701 Dehumidifier
Amana ABB1927DE Bottom Freezer Refrigerator Logo
67 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
