Question about Kenmore Freezer 24462
I have a Kenmore freezer model number 253.23414100 and the warning light and buzzer is going off. I noticed water coming from underneath and the outer side walls are very warm/hot to the touch. I manually defreosted it and turned it back on. About 30 minutes later the alarm went off again and once again the outer side walls were very warm. Any ideas or suggestions would b greatly appreciated.
SOURCE:
  • 323 Answers
SOURCE: Kenmore Upright Freezer Alarm
1. You can hear the compressor running.
2. The temp setting you turn the thermostadt to starts and stops the compressor.
3. Look in your manual for a reset button and the location.
4. If you are familiar with a meter, grab the manual and check it it. But I doubt it is the resistance.
5. Sounds like a bad motor or low freon. If you have a lot of food in it, and the above didn't work, bite the bullet and call a repairman, although it sounds like much of the food is past saving if it is really defrosted.
Posted on May 12, 2009
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
SOURCE: temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Posted on Feb 25, 2010
  • 949 Answers
SOURCE: Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Posted on Apr 25, 2010
  • 141 Answers
SOURCE: Temperature warning light keeps going off. Resets
hi brian 20 degrees is too warm for a freezer i think you may have a dirty condensor coil its usualy under the freezer or on the back also check and if it has a fan on the outside make shure its turning let me know what you find and you can e mail me at [email protected]
Posted on Jun 09, 2010
I have an older model chest freezer. The alarm buzzer and light came on. I silenced the buzzer but the light is still on. The freezer is cold and still freezing well. Door is good and closed. It’s running...
Without a posted make and model number, it is hard to say. You need to unplug the unit from the power for a couple of minutes and then plug it back in to see if it resets
May 25, 2018 | Freezers
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
DRAINAGE IS CLOGGED
There is no part number for the drain. find a piece of copper tube that fits inside the hose and ease it up inside the broken drain hole but only a short way. Silicon seal around underneath it
Apr 19, 2012 | Kenmore Freezers
Jun 09, 2010 | Kenmore Freezers
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2010 | Freezers
Warning buzzer sounding
this is usually an indication of a temp. problem you need to check the seal around the lid,make sure there is not gaps and or the door was not left open.
Jan 31, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Kenore Elite Freezer is hot on the sides
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 16, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore Freezer 24462 Logo
217 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
