Question about Compaq Presario 5240 (353200-003) PC Desktop
I can't get into the BIOS settings
I am a begining programming student, and at this point extremely frustrated. At first when POST checked the RAM all numbers were white, now all of them are yellow? I need to get into BIOS to boot from CD to install an OS. I have tried all that I know to do, with the exception of placing the tower under the back tire of my truck and destroying it, but that doesn't accomplish what I'm trying to do.
  • 3 Answers
You should be able to get into the BIOS on a Compaq PC by tapping F1 as your turn on the computer. From there, you can reorganize the boot devices. Press the right arrow to select Boot. Press the down arrow key to select the CD-ROM. Press the + (plus) key to move the CD-ROM up until it is the first item in the list.
For the RAM issue, If you have 2 or more RAM sticks in your PC, pull one, boot, and if everything works, then the pulled stick is bad RAM. If not, replace stick #1 and pull stick #2, etc.
In general, make sure that your RAM is seated properly and locked into place, and that you discharge any static electricity before getting close to the RAM/MoBo, etc. (I usually touch the Power Supply Unit PSU as soon as I open the case to discharge through the ground on the power cable - keep it plugged it).
If you can't get anything to work, see if you can boot up with a live Linux CD or USB. I personally use Backtrack 3
http://www.remote-exploit.org/backtrack_download.html
But systemrescuecd is pretty much the standard: http://www.sysresccd.org/Main_Page
Use imgburn to burn the downloaded .iso file. http://www.imgburn.com/
I have recovered data from dozens of 'fried' PCs with Live Linux CDs - much better than paying geek squad a few hundred bucks to do the same thing. It'll also help you verify hardware issues (ie, if the RAM gives you trouble in both XP and Linux, then it's a hardware issue, not a software issue).
Hope this helps!
Posted on Jun 07, 2008
Are there any recommended bios settings that are different from the default settings?
If the laptop randomly runs extremely slow - it's almost certainly due to a background process using up the computer's resources. Run Process Explorer to find out -which- process this is.
I know you said you've already eliminated this as the cause - but I believe you missed it due to the random nature of this problem.
No BIOS setting will resolve this problem.
Aug 15, 2014 | Dell Latitude E6520 Laptop Computer 500 GB...
Hp pavilion ze 4200
Hi, Your post may refer to three (3) settings: 1) BIOS for the laptop/hardware itself or the 2) operating system or 3) password. BIOS - Upon restart, when the logo screen is displayed, press F2 to enter BIOS Setup. OS - to really get back to the beginning: 1. Go to System restore and click on the first/earliest date of restore point. This would perhaps be the earliest backup of your system and everything will revert to as to how it was then; or 2. Reformat, clean/fresh install of Windows. Now if you are referring to forgotten BIOS or entry password, you have to bring it to HP service with proof of ownership/purchase and other documentations. Good luck and kind regards.
Aug 26, 2007 | HP Pavilion ze4220 Notebook
Malfunctoning keyboard while using Hotmail
If it only happens when using Hotmail, it is not your keyboard. Check your anti-virus, anti-spyware programs, could be a bottleneck.
Sep 03, 2009 | Dell Inspiron 1501 Notebook
When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
the ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Mar 06, 2009 | Computers & Internet
I HAVE A COMPUTER WITH CONFIGURATION OF INTEL EXTREME DP45SG MOTHERBOARD,QUAD CORE 6600 PROCESSOR,NVIDIA GRAPHIC CARD,DDR3 RAM(1333 HZ),500GB HDD(SEAGATE) and still my compuer screen shows NO DISPLAY...
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Ok try all this first...
Feb 27, 2009 | Dell Dimension 4600 PC Desktop
New asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Aug 23, 2008 | Intel Motherboard
ASUS P5N-E SLI
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Jul 06, 2008 | ASUS P5N-E SLI Motherboard
My computer beeps on start up nothing on screen and beeps over and over again, I checked the jumpers, checked hte cpu pins for damage, check the RAM and replaced with new to test, checked my drives nothing...
Try putting in a PCI vid card. Just an older one. Not a PCI- Express unless you have one.
I had the same problem. And the dipwits at ECS programmed the BIOS to default with an PCI vid card. Not on-board.
Then, just go into BIOS and change the boot 'Init Display first' to "on board" or something like that under PnP/PCI Configurations.
Under "Advanced Chipset Features" 'Onboard GPU' make sure it is {Enable if No EXT GPU] or always enable or something like that.
Believe me I had the problem. Was ready to dump it, or do a RMA. Messed around for a year and 1/2 then as a last resort put in an old 2mg PCI card. And it booted right up. I was pissed as hell that they would set the default to an EXT card on a board that claims to be ONBOARD video. Believe me they are going to hear about it.
Also depending on the ram installed. As I am having this problem. Now. It defaults to single channel DDR2. And I can only get 1 533 stick to work. For some reason, the board refuses to post when I have the second of a matched pair in the slot. So if you have that - try taking out the second stick. But try the video deal first.
Feb 13, 2008 | ECS C51GM-M Motherboard
Compaq Presario 5240 (353200-003) PC Desktop Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
