Question about Canon Video Cameras
Loss of live viewing
Hi, my camcorder is just 4 years old & has been hardly used but I have lost the live pictures both via the LCD screen and the viewfinder. If I play a pre-recorded tape in the machine then this can be viewed via the LCD screen. Can you tell me if there's something I can do to rectify? Many thanks
  • 10,594 Answers
Can u tell me model number n make of ur camcorder?
Posted on Jun 07, 2008
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A300 Digital Camera
How do I get the sony handycam dcr-hc30ntsc to show me a pictuer wale recording or any thing
If camcorder does not show live view in view finder and lcd screen but shows good picture in play back of old recorded tapes then ccd imager chip is defective in camcorder and need to be replaced.
It is not user level repair as soldering work is needed to replace ccd imager chip.
Let me know if you have additional question.
Thanks.
Oct 18, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Screen black. Everything else works perfectly.
To my understanding that you do not see live view in camera mode to record and camcorder playback old recorded tapes correctly and you get picture in LCD.
If it is true then please check lens cover that need to be slide down to get live view in camera mode. If problem still exist then 2 possibilities, either aperture in lens mechanism is bad or ccd imager is defective.
In that problem, camcorder needs qualified tech to fix it.
Let me know any further query.
Nov 03, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD View screen problem Sony DCR-HC42
well if i'm not mistaking it could be the LCD board connection at the screen . but the replacement + labor will go from 120 to 170,
have you tried to open the screen, really slowly and see if it shows any life !.
you can try to get an stimate at sony, and see how mush it will cost you repair the machine.
there is not easy way to fix it, the screws are small and they can be lost really easy.sorry
Oct 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
LCD screen doen't display the view
So camera doesn't give live view to take picture? and you can view old / stored  pictures OK, is it?
If yes, then it is problem of CCD imager in Canon A80 and this part needs to be replaced.
Canon will repair your A80 free of cost as per announced scheme of CCD imager support.
Click Canon CCD Advisory to know how to get free repair facility.
Jan 07, 2009 | Canon PowerShot A80 Digital Camera
Moisture detected
Take the battery pack off and hit it (not too hard) with the palm of your hand. It SOUNDS CRAZY but my own camcorder had the exact same issue and all it took was one hit- put the battery back on then powered it up- VIOLA- it works! I am not kidding, try it. You'll save LOTS of $$$$$. This is NOT a joke.
Sep 07, 2008 | Video Cameras
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Video Cameras Logo
65 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
