Question about Motorola Mobility i850 Cellular Phone
I850 Large Screen problem
Ok......
the large screen doesn't light up but when i put a flash light to it u can see everything how do i fix the back light on this?
    Problem Solver:
  • 18 Answers
The backlight on the phone has probably burnt out. The only way to fix this problem is to get the flip on the phone replaced. This will work almost 100% of the time.
Posted on Jan 28, 2009
Dell st2410b monitor won't stay lit
Ok, same issue here as well. Monitor would come on for 1/2 second and then the backlighting will go off. It's next to impossible to tell, but if you shine a bright flashlight at the screen, you can make out the video signal/desktop.
I have now replaced all the Capacitors except the very large one (didn't come with the kit that was available.) None of my caps looked bad (bulging) including the large one. Unfortunately, I still habe the same issue
So my question is....large capacitor replacement or something else?
Nov 29, 2012 | Dell ST2410 Monitor
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
This large 52" projection tv
It sounds like arching if you look in back of set when this happen you should see a light flash, this could be the High Voltage Flyback or transformer bad.
Jan 23, 2011 | Televison & Video
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
I850: i put a boost sim in a nextel i850 and it worked f...
Sounds like the software has been corrupted...it need to be flashed to fix the software.
May 18, 2010 | Nextel i850
Everything has gone large on my screen
This will only work for VISTA . Click personalize then click on display settings then click on the monitor icon. Put your resolution on 1280 by 800 then press then click on colours HIGHEST (32 BIT) then press ok ....
Dec 02, 2008 | HP Compaq Presario R4000 Notebook
Screen
If the inside screen and the outside screen is blank, the possible problem is the LCD flex cable. But if the outside sceen is on
but the large inside screen is blank. The large screen could be defective.
Aug 11, 2008 | Motorola Mobility V300
Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identicle. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
Jul 12, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Motorola Mobility i850 Cellular Phone Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
