Question about GE JBP82 Electric Kitchen Range
Replacing Glass Cooktop on GE JPB82
Hi I have a crack in the glass cooktop of my GE JBP82 range. From looking online and reading, it seemed that all I needed was the cooktop piece and I could unscrew the elements and replace the top which would be cheaper than an entire replacement range.
I got the replacement top in today but it seems the metal frame that holds the elements on the (old) cooktop is bonded to the cooktop. Can anyone confirm if this is correct- is there an adhesive used on these frames? I believe I have removed all of the screws/brackets. And if it is bonded is there a way to remove it or am I going ot have to buy replacements elements/frame as well?
Thanks!
  • cortadito Jun 07, 2008
    Thanks for the fast response!
    Hmmm... let me see if I understand and maybe clarify a bit. I did pull out the cooktop by removing the two screws underneath the top above the oven door and then swinging it up off its hinges at the back of the unit.
    Then, I removed the two brackets (I believe those are the 1/4 inch screws you are talking about) that hold the frame that the elements are in, but the frame is adhered to the top. The replacement top doesn't have the frame that the elements individually latch into and I was hoping that frame just came off all as one.
    So while I could remove all the elements from the frame, I have no way to connect them to the new top.
    Does that make sense?
    Argh. Looks like I have the wrong part number- similar model but not exact. And of course the one I really need is $100 more!
  • 868 Answers
1st....You have to pull out the cook top first.2nd...remove the 1/4 inch screws that hold the top down(they are mounted on the side os cook top ) ,you dont remove the lowest ones.remove the burners from the top and your there :) Please Rate This !
Posted on Jun 07, 2008
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
CRACKED GLASS GE - JB968
1 Unplug cooktop or disconnect power.
2. Remove the cooktop from its mounting
location, (see “Installation Instructions” in
Section 2). Position the cooktop so that
you can access the bracket screws below
the cooktop glass
3. Remove the fourteen flat-head screws
from the front, rear, and side ceramic glass
brackets.
4. Remove the two small side brackets from
the cooktop base.
5. Lift and remove the ceramic glass from the
Oct 13, 2008 | GE Profile JB968 Electric Kitchen Range
I have frigidaire electric range FES367DQA. I cracked the cooktop and would like to replace it. I found that there is no glass cooktop for my range but there is for FES367DBA and DCA. The difference i
Thank you for your post, isaak goldman!
I understand that you are seeking instructions in order to replace the cooktop on your Frigidaire range. However, this is not a simple DIY job. I would recommend having a professional technician come out to ensure that the range is properly disassembled and the cooktop installed correctly to prevent any future issues. Hope this information is helpful. -Matt
Jan 31, 2015 | Frigidaire Kitchen Ranges
Looking for Glass-Ceramic Cooktop for GE Range, Model: GRSR3920ZWW-3
I am sorry but we have no parts or anyway to refrence them here at Fixya. Contact GE customer service for parts.
Aug 31, 2012 | GE Kitchen Ranges
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have GE Profile glass cooktop. After cleaning
you can safely use a razor scraper such as you would use to scrape paint. It will not harm the surface and then you can polish it with the cleaner.
Apr 07, 2009 | Kitchen Ranges
Cooktop glass broken - need a replacement - where can I find it?
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
Dec 23, 2008 | GE Profile JP930 Electric Cooktop
Deep scractches on glass stove top
hi there,
you can try and use a cleaner intended for glass cooktops. if the scratches are deeper than that, i would recommend replacing the cooktop itself, as the heat from the elements may cause it to crack.
thanks
Sep 30, 2008 | Kitchen Ranges
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE JBP82 Electric Kitchen Range Logo
692 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
