Question about Neff Dishwashers
Lower door seal, dish washer
I seem to be having a problem finding the right part for my built in dish washer,
the information I have from the sticker onthe front door plate is.
SV 331
02248314 23
030857 DS GB
  • 77 Answers
You need the info from model plate inside the D/W . usually on front edge of tub, near the gasket. with that info and brand name of unit you should be able to locate the part form local parts store.
Posted on Jun 07, 2008
How do I go about replacing the door seal on a Bosh SHX46B02UC/21 dish washer.
If you mean door gasket then the assembly diagram is on this site. see item 6. Follow the drawing and see how it is attached to the cabinet.
If it is the lower door seal which is at the bottom of the door then see this diagram. see item 4.
Aug 20, 2011 | Dishwashers
Soap dispencer door dosnt seem to be opening at the right time. i find the soap undisolved in the bottom of washer, and dishes are not clean.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
Feb 09, 2011 | GE Nautilus 24" Built-in Dishwasher
Water leaking from bottom of door-LG LDF6810ST while dishwasher is washing dishes
could be door seal .or some time use the right dish soap, door may d need ajusted
Apr 11, 2010 | LG LDF6810ST Stainless Steel Built-in...
Whirlpool Built-in dishwasher Model DU8700XB -O
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Dishwashers
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
LG Dishwasher redepositing debris back onto dishes
Have had a problem with our LG 5811 Dishwasher not operating.
I have found the Vent Hole Cover located inside the Door was not installed correctly. I used plumber putty between the plastic fitting and the inside face of the Door and turned the Cover fully to lock in place (vent hole is toward Door bottom). Water was leaking previously from this opening over the wires in the door.
Another problem was the lower Door Seal (under the Door) it was not installed correctly either. It was actually too long and would not seal against the bottom of the inclosure. Water was coming out and spraying the wires in the door. I had to remove the metal stiffener over the front of the Dishwasher to get to the Door Seal. I removed one end and reinstalled the seal. The Seal laid flat but was approximately 3/16" to long. I cut off the end with a sharp knife - seems to be the correct length now.
May 23, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Leaks badly
Most dish washers do not seal at the bottom, the door lip just sits
in front of the tub lip and does not make a real tight seal like a refrigerator door, so unless water is spraying out the top and sides of the door,I would assume that it is either overflowing,or you are using the wrong detergent and it is just foaming to much inside the washer and going over the lip and dripping on the floor. Once the suds stop getting agitated then turn back to water and don't look like suds.
So if you watch the washer during the cycle and the water s only coming from the bottom it is the water level switch inside on right
in the front,looks like a mushroom, once the washer reaches a certain level of water this switch floats up and shuts off the water to stop it from filling anymore. If this seems to be the case just remove the front bottom kick panel and you should be able to see the switch, watch it when the washer is filling,you can also push up on the little arm and the water should shut off. Post back with any questions.
Apr 16, 2009 | LG LDF6810ST Stainless Steel Built-in...
My frigidaire dishwasher leaks from the bottom right of the door. It forms a puddle while running a load of dishes. Looks like the seal is gone underneath the door on the right side. Any idea how to...
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it to leak out of the front and sometimes not to drain all water out. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem. Also could have a bad door seal. Check for any tares in the gasket.
Apr 11, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
My dishwasher is leaking and I think the water wash level is to high. Is this adjustable. Thanks Geo.
Hi if your dish washer is leaking you need to replace the door seal please try this first look at seal for damage around the door warter should not come past this seal thank you for useing fixya please rate me
Mar 18, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
188 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
