Question about Belkin Computers & Internet
I have purchased a belkin wireless g usb adapter 802.11g. have load on signal very good but not enabling me to contect to my wanadoo broad band .please advise on some poss solutions
TO SECURE THE NETWORK CONNECTION
Posted on Jun 07, 2008
What's N stands for in this product (Belkin F5D8053 N Wireless USB Adapter for Desktop or Notebook PC)?
Based on the 802.11n draft, N Wireless enables multiple receivers and transmitters to send and receive data using Intelligent MIMO (Multiple Input Multiple Output) spatial multiplexing techniques which greatly increases speed, coverage, and the reliability of the wireless network.
Sep 25, 2012 | Belkin F5D8053 N Wireless USB Adapter for...
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My compaq presario V2000 will only connect to dialup
To connect to your DSL internet you will need an ethernet port or wireless card on your laptop. Your laptop should have an ethernet port, it will look like a phone jack but a little bigger. In the off chance that you don't have an ethernet port on your laptop you can also purchase an ethernet to usb adpater. You may have a wireless card installed on your laptop, but if not you can purchase a usb wireless adapter. To use your internet wirelessly in your home you'll also need a wireless router. All of these things can be purchased at your local electronics store (walmart, best buy, kmart, frys) and usually are fairly easy to setup with the included instructions.
Feb 15, 2010 | HP Compaq Presario V2000 Notebook
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Do Desktops pick up internet connection like laptops do? Im planning on purchasing a desktop pc however im not sure if i can pick up internet like my current laptop does, U see i just moved in and dont...
Hi there.
You hit the nail right on the head!! desktops don't come wireless enabled so you will need a wireless card installed into it.
I recommend a wireless PCI card as a Dongle are not that good and can be easily broken.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Computers & Internet
Connecting to secure network
when enabling wireless security the router and adapter must be both be configured and configured in a fashion that both support. If you need help provide confirmation of your wireless router's manufacturer and model and the same information for any wireless adapters or computers with built-in wireless adapters to be wirelessly connected.
This will allow us to determine the common security options for all wireless devices you have.
Dec 16, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Bt broadband wireless
Go into your device manager and check and see if the usb connections are active and not turned off. If thats all ok open your network connections and make sure you see a wireless adapter there you should see two connections there, one should be lan adaper, and two should be wireless adapter. If not I need a little more info. Just write back to this sight and give more info what operating system your have wireless card ect. anything that will help, I hope this helps you out, usually you can fix it a couple differant ways you can email me anytime for more info.
Dec 12, 2007 | D-Link AirPlus DI-524 Wireless Router
Connection problems
Is wireless connection enabled in your routers wireless settings and not encrypted in any way until a connection is established. Make sure your router is set to enable DHCP, as this will give your wireless card an IP address automatically. Ensure your card is set to obtain an ip address automatically. If not look in your routers setup(normally by typing 192.168.2.1, in your internet browser) to see what IP address and DNS address it has given your connected pc (eg 192.168.2.3). Then go into your cards properties and use the IP address 192.168.2.4, but the same DNS address(probably 255.255.255.0); then re start the wireless pc and the router if neccasary. If you still get no connection, ensure wireless light is on; on your router, and you have no obstacles in the way of the signal. If you are using WEP encryption it is normally a Shared key setting rather than an open key setting. Please reate this solution.
Nov 20, 2006 | NetGear Wireless-G USB Adapter...
Computers & Internet Logo
55 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
