Question about Samsung Refrigerators
Samsung SRS2029CSS ice maker in side by side, won't drop the ice out of the tray. The ice stays in the tray and after turning back upright, the water dispenses again flooding the freezer. I've taken it apart and can't see anything at all wrong.
  • 2 more comments
  • Pepsii Jul 29, 2008
    Many thanks. Filter changed, freezer defrosted and ensured that no ice remains in the tray, but still it refuses to drop out of ice tray when it turns.
    The ice won't drop out of the upturned tray - it just stays in and won't drop out. Otherwise, the icemaker itself appears to be working perfectly.
  • Anonymous Mar 16, 2014
    How do I take the ice tray out of my side by side samsung
    How to take out the ice tray in a side by side samsung
  • 958 Answers
The ice maker twist the tray in harvesting the ice. pls observe whats holding the ice.
it could be that the twist is not big enough or is not turning enough to break the ice and fall on the bin but if it is not breaking up, it would not fall and would just come back to the tray.
another problem could be that the ice are too big. you can adjust the amount of water coming in so that the ice would be a little bit small and they would not be attached to each other if too much water is in the tray.
and last , you can manually feel the rubber like tray where the ice is being formed. it could be rough and not smooth and the ice would not drop fast.
i hope i was able to solve ur problem..
tnx,
drcool
Posted on Jul 29, 2008
  • 2,071 Answers
WHAT IS WRONG WITH YOUR ICE MAKER?
Samsung SRS2029CSS ice maker in - small_1_6.jpg For a detailed Ice Maker illustration, click below.
redarrow.gif In Freezer Free Standing
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There are three common problems with icemakers:
There's no ice
Small or too few ice cubes
Specks in the cubes
  • LORETO LACARON
    LORETO LACARON Jul 29, 2008
    Yes replace the Motor Module. The motor does
    not have enough power to remove the ice. It is real easy. You take the
    Ice Maker out of the refrigerator, and take the front cover off, and
    then take the 3 phillps head screws out in 3 of the corners of the
    motor module, and then take the wire sensor off, and then pull the
    motor module out, and put the new one in.
    ApplianceEducator.com
    hope this may help;
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
    President:
  • 2,712 Answers
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jun 07, 2008
  • Swilin Sampson
    Swilin Sampson Jun 07, 2008
    You could also try unplugging the unit for a while to melt the ice cubes. It could be that they are frozen stuck in the tray. You may wish to consider replacing the inline water filter as well. Your refrigerator water filter is most likely located either inside the
    refrigerator cabinet, near the top or in the grill at the bottom of the
    unit.
  • Samsung Master
  • 13,433 Answers
Have you tryed defrosting it?
I have a Samsung rs261mdrs side by side refrigerator. The ice maker quit working. I replaced the ice maker, it filled with water after a few hours I check for ice. It's frozen in the ice tray but won't...
Is it that the ice maker unit won't drop to the tray ? or the ice from the tray will not dispense trough the door? I need more clarification to try to help...thanks
Mar 04, 2015 | Samsung Refrigerators
How to replace samsung flex-tray ice tray
On my model RF265AABP, it is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out. Yours may be different.
z
Ice maker assembly upside down on bench.
Apr 10, 2013 | Samsung RS2530BBP (25 cu ft) Side by Side...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
Icemaker tuns but ice does not drop out
OK the reason the Ice isn't dropping is that the element under the icecube tray isn't working. You'll need a new Ice tray with element I'd be guessing, but see how you can buy it. Some models you need a whole new ice maker. Cheers
May 21, 2009 | Samsung RM255LASH Side by Side...
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
286 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
