Question about Kenmore Dehumidifiers
Broken shut off lever
My 5 year old snapped the plastic shut off lever. Any chance to re-attach it or do I order a replacement part/tank?
  • Anonymous Mar 15, 2014
    The float lever is snapped of can I get a replacement tank
I saw a website that had parts.
http://www.appliancefactoryparts.com/dehumidifiers/helpcenter/breakdowns/maytag/maytag-m3dh30b2a-b.html
Looks like the float with the plastic tab was $7.99.
Posted on Jun 10, 2008
Fill light on and beeps but holding tank is empty
If it is like mine, the plastic part attached to the float in the collection bucket is broken and no longer actuates the switch that indicates the collection bucket (holding tank) is full. When I checked several years ago, the replacement part was no longer available. I used tape to keep the switch in the position that allowed the dehumidifier to operate and attached the hose connector to allow the condensate to drain. The collection bucket isn't needed anymore with this arrangement.
Oct 24, 2012 | Maytag M7DH65B2A Dehumidifier
Where can I get hose ,hose attachments for my Goldstar dehumidifier? Can not locate my manual or attachments.
Fortunately, it doesn't require a special hose, as a standard Garden Hose Connection is on the left side of the water collection bucket. You may have to carefully drill a 1/4 " hole in the center of the connection, once you unscrew the drain cap. The hose should be no longer than 5' , as the drainage relies entirely on gravity to drain.
When attaching the the hose, be sure that the female hose connection has a washer in it or it will leak. Hand tighten the hose connection firmly, being careful not to crack the plastic hose connection on the tank. Also, be sure that the float valve in the tank is in the DOWN. position or the unit will not run.
Hope this helped you. Please let me know.
Jul 08, 2011 | Goldstar DH304 Dehumidifier
I have DE400P and water not collected in a tank, it's coming from the smal plastic tub behind tank
There's a small gray nub attached to the plastic above it. Slide the tube onto it and it should fix your problem.
Jun 24, 2011 | DeLonghi DE400P Dehumidifier
The red indicator light just flashes when i turn the unit on. Whats wrong?
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Good luck.
Aug 12, 2010 | Kenmore 54351 Dehumidifier
Soleus 40 pint dehumidifier... used for 3 years, stopped making water. Recently overfilled, auto shut off hadn't worked and water level overflowed. 2 days later can't get to make water. Tried all the...
Check to see if the styrofoam is still in the lever of the shut off arm. It's atop the water reservoir. If there is nothing there it will not float causing the arm not to shut off.
Nov 25, 2009 | Soleus CFM-40 Dehumidifier
Compressor kicks on for about a min then shuts down overload trips out
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 29, 2009 | LG LHD45EL Dehumidifier
Should I buy a new Ebac dehumidifier?
Unfortunately, Ebac has discontinued their HD line at the moment. The only other bucket style dehumidifier that they currently manufacuter is the CD35 dehumidifier.
Jan 31, 2009 | Ebac HD880 Dehumidifier
No Power
Found the fuse at this website www.tiewraps.com ORder the AG-12
Jun 27, 2008 | Haier HDN655E Dehumidifier
Doesn't want to stay on...
Most likely the fan motor has broken. Without the fan, the compressor will overheat. There is a safety device inside that automatically shuts off the compressor to keep the overheating from destroying it. Check to see if you can feel air movement in the front or back of the unit while it is running. If not, then the fan motor has definitely broke. I had this exact problem on mine.
If you take the unit apart, you will find a parts list inside the unit. It will be inside a small plastic pouch. You can order a new fan motor from Sears. The cost is $30 plus shipping.
You will have to move the condensing coil in the front out a bit in order to exchange the motors. Just be careful not to break any of the copper lines. They are copper so they will flex quite a bit without breaking. Still, use caution. If you break the lines, all the refrigerant will leak out and your unit will be useless.
Sep 01, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
117 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
