Question about Acer TravelMate 2300 Notebook
Travelmate 2308 hard drive
Hi. The hard drive keeps resting after a short time of inactivity. This is causing a couple of seconds of freezing when it fires up again. Is there a way to change the settings so that it runs constantly?
  • 458 Answers
Hello Goober....
Sure , You can change the settings here:
Click on Start (bottom Left corner of screen)
then...
Click On Control Panel
then...
Click on Power ..or "Power Options"(the icon for power settings)
then..
look there for what is Checked and Unchecked.... (in windows vista- you will have to first click on.. "change plan settings")
Once there.. You can change how your hard drive Runs... in Windows XP you just set the hard drive to .. NEVER... or you can simply set it to shut off after 30 minutes or an hour...
In windows Vista, to set the Hard Drive settings you will first need to click on...Change Advanced Hardware Settings...
Then Choose Hard Disk...then edit the settings there...
Hope it Helps... Happy Computing
http://www.wnycomputerpro.com
Posted on Jun 07, 2008
Presario cq56 with windows 7 freezes after inactivity of 20 minutes
Hi there,Try this:Click on control panel>Programs and Features then remove any program that you don't need.The ones that have a lot of memory because it sounds like you may be running out of memory.I recamend a free utility that is number one in it's class. Advanced SystemCare Free http://download.cnet.com/windows/?tag=ftr There will be a list on the right side and this app is number 5.I use this all the time.....If this doesn't work you could try a system restore.If you have any questions feel free to ask.Thank you for choosing FixYa. by the way you push one button and the app dose the rest but you have a chance to decide yes or no (love this app)
Nov 30, 2011 | Compaq Presario CQ56-115DX Laptop
Hi, I have an Acer TravelMate 5520, it will not boot up on the screen. The green power light on the on/off switch,the green light indicated by a lightbulb shape and the green light at the top which is...
Sorry to hear you're having trouble with your notebook.
The book indicator you referenced is the hard drive activity light. When you see this flicker it indicates the hard drive is being accessed.
With the notebook booted up, press Fn+F11 a few times to enable and disable numlock. If the numlock light(lock with the number '1' on it, next to the hard drive indicator) turns on and off then the problem may be only related to your monitor and not a failed hard drive, video adapter, or something like that. Believe it or not this could be a good thing.
With the computer booted up, press Fn+F5 and wait a couple seconds. This will toggle the display modes. Press Fn+F5 a couple more times to cycle through all the modes.
Also try pressing Fn+F6. This keystroke blanks out the display to save battery.
Do you EVER see anything on the screen while the notebook is booting up? You should see the Acer splash screen and maybe some information about entering the BIOS setup.
If you have an external monitor and a VGA cable(or DVI or S-video) you can connect the external monitor to your notebook then turn the notebook on. You may have to do the Fn+F5 keystroke after connecting the monitor to select the correct display mode. This will help us determine if the problem is the notebook monitor or not.
Here is a link to the manual if you need it:
http://global-download.acer.com/GDFiles/Document/User%20Manual/TM_5520_5220_ENG-OLM-0307.zip?acerid=633645712974910948&Step1=NOTEBOOK&Step2=TRAVELMATE&Step3=TRAVELMATE%205520&OS=ALL&LC=en&BC=ACER&SC=PA_7
Apr 19, 2011 | Acer TravelMate 5520 Notebook
I have a frozen acer travelmate netbook that had frozen drive d and c. whenever i open my laptop, it freezes after displaying windows xp. i tried using ctrl+alt+del / ctrl+alt+shift / ctrl+shift+esc but...
sounds lile your Windows operating system or hard drive has become corrupted or damaged. Try to repair Windows or reinstall it using an external optical drive and your Windows CD or restore/recovery CD. If might also be necessary to fully reformat the hard drive and reinstall Windows. If that still fails, it might indicate a failing hard drive
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
For the past couple of days, every show our DVR has recorded freezes a couple of minutes into playing it and the DVR reboots itself. This always occurs at the exact same time on that show. We don't have...
Hi, Mary with Dish Network Customer Service. Since the DVR is the only thing having the freezing issue, it sounds like it maybe a hard drive issue. I would recommend resetting the receiver. Unplug it from the power supply for 10 seconds and then let the receiver reboot itself. If you are still having this issue, I would recommend calling Dish Network and we will need to replace the receiver. Hard Drive issues do not resolve themselves and only get worse over time. Please let me know if I can be of further assistance.
Jan 13, 2011 | DISH Network ViP722 DTV Receiver /...
Hello, i have an acer TravelMate 270. My laptop cannot boot correctly. When ever it gets to the logging on fase to put in a password you see the windows is starting up for a split second and then it turns...
Well u can try to format the drive and load a fresh copy of the operating system. When its using short term memory to dump its boot errors then its never a good sign. Viruses cause this most often but a bad sector on the hard drive itself will also do this. If after you format the drive and still it does this then its time for a new hard drive.
Aug 13, 2010 | Acer TravelMate 270XV Notebook
After using the hard drive for a couple of years and then 3 months of inactivity it now will not start. It tries to start and then shuts off. It does not show up in computer list of drives. I am running...
Check to make sure the drive letter is not in conflict with a drive letter on your computer. Second you can send the drive out to a drive recovery house and pay someone to retrieve the information will have a good price tag about $2.00 a gigabyte
Mar 13, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Freeze problem with Acer Travelmate 254 LC
You just need it to rest for a couple of days, if it does not work, then try turning it on and leaving it on charge for the same ammount of time
Apr 11, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Download freeze
Is this when you try a second and third time to download the same movie? Try a different one. Update to version 2.2 (came out last night). It has upgraded reliability for the internet. Hopefully that helps. Good luck!!
Mar 16, 2008 | Sony Playstation 3 (PS3) Console
Laptop cer travelmate 4000
Are you getting an error?
Try power draining it by taking out the battery and ac plug, then holding down the power button for 60 seconds. It may start up but this isn't a fix.
The freezing at windows sounds like a Spyware/Virus issue.
If there is no display at all, it's probly time to buy a new one.
You can send it in for repair but by the time you get the bill you probably should have just purchased a new one.
Mar 14, 2008 | Acer TravelMate 4000WLCi Notebook
Freezing up
A few things to try. Check the event logs on your PC for Hard drive errors. If the lockups are random they could be caused by bad blocks on your drive in a paging or system file. If you see disk errors, replace the drive immediately and make sure to keep proper backups. Next, update all drivers, especially the video driver. Often lockups will be caused by Video driver corruption. Dont be scared to install beta versions of drivers for your laptop in an attempt to resolve the problem. Next, search out a utility boot CD from the internet. There are several, usually running linux but most contain a memory test utility that you want to run for a long period of time (several hours) to see if after a stress period you start getting memory errors. Next, search for speedfan on google and install it to monitor the temperature on your processor, this problem could be caused by dust buildup on the processor heat sync or cooling fan. Generally it would take some time to have this problem lock up the system, however, after the first lock up and reboot subsequent lockups would happen more quickly. Many laptop repair depots will do a service for under $100 where they will dissassemble the machine, clean the heat sink and fan (or replace it) and apply new thermal grease.
Jun 20, 2007 | Acer TravelMate C312XCi Tablet PC
Computers & Internet Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
