Question about Frigidaire Kitchen Ranges
Need instructions to start self cleaning cycle on gas range
  • 868 Answers
Model / serial number helps....
Posted on Jun 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Error Code F7 during Self-Cleaning
This indeed indicates a problem with the Electronic Range Control (ERC). The part number for your range is 769758 and costs about $120. You can find the part at repairclinic.com and have it shipped directly to you for a modest shipping fee. If you need further guidance let me know. I hope this information is helpful.
Posted on Jan 29, 2008
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Posted on Mar 10, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Posted on Mar 14, 2008
SOURCE: After running self cleaning cycle, oven won't heat.
I own a similar range. As you can imagine I was dismayed to find out that my $6000 heap can't run a clean cycle, unless of course you just don't want to use your oven again. let me give you a tip something WILL break on your oven every time you use the self cleaning "feature".
The first time I used the self cleaning feature the board burnt up, I asumed hat this was a fluke. The second time the pvertemp sensor burnt out. The next few times that I was brave enough to try it the overtemp sensor triggered this is what I hope has gone wrong with yours since while it's not easy or convenient to fix it is free. If you pull out your range and remove the backsplash and then the rear panel there should be a breaker with a button you can push to reset. On mine it is located near the top of the oven compartment on the left side near the middle. I hope that works for you and you will soon learn as I have after doing this a few times that the self cleaning cycle is just not worth it. It willdo this every time and it really is just easier to use easy off and clean the oven by hand. I realize that is not what you had in mind doing when you bought a luxury Item like a 36" thermador range, but I hope you don't have to hate yours as much as I hate mine.
Posted on Oct 28, 2008
aborcass
  • 2651 Answers
SOURCE: Control Panel went blank after self-clean cycle on gas range
youll need to pull unit out and remove the back cover, probalby 15 screws or so then youll find the thermal fuse located toawrd the top in the middle 2 wires leading to it, ble and white striped. heres the part number to order 8300802.. LIVE WIRES DISCONNECT POWER!!!!!!!!
Posted on Dec 02, 2008
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
I started a self clean on my oven, and then shut it off, the door opened, now it will not close, seem like the latch is in the lock posistion. help
For an oven self cleaning problem, the first thing to check is the door lock motor and switch assembly. Every self cleaning oven door has a locking mechanism to prevent the door from being opened during the cleaning cycle. An oven self cleaning problem often happens after a clean cycle has been run. If that happens, more often then not the lock assembly will need to be replaced. The door lock motor and switch assembly, over time, fail due to the high temperatures that are encountered during the cleaning cycle.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 02, 2013 | KitchenAid KGRI801PBS Gas Kitchen Range
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
I do not know how to use the self clean feature on my Kenmore Gas stove
Hi
Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Please post back for any further assistance. Hope this helps...
Daniel
Aug 28, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Gas Range
Hey Alan- 'Self clean' sells. Techs call this function 'self- destruct'. Depending on age and number of previous 'clean' cycles, the control may have developed errors, or lockout switches may not function. If inside is thoroughly scraped, and bottom pan checked, removed, and cleaned if necessary, oven should work fine. Preventitive drip pans and a lot of aluminum foil keep the 'Self Clean' Gremlins away. Hope this helps- Thanks- ED
Feb 25, 2010 | Kenmore 73053 Gas Kitchen Range
How long does self cleaning take?
Self clean mode can vary between makes and models of kitchen ranges, but it usually averages 2 to 4 hours. Once the self clean mode has been started it cannot be stopped until it completes the cycle and cools down. The oven door will lock and will not unlock until the internal oven temperature cools as the oven will super heat to about 700 or 800 degrees. Some manufacturers will enable the consumer to vary the self clean cycle time. Refer to your owner's manual under the Operating Instructions for specifics.
If you no longer have an owner's manual, you may be able to obtain one on line at managemylife.com. Just type in your model number under the "Manuals" link and see if it is listed. They have an extensive list of owner's and installation manuals available in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 04, 2010 | Frigidaire Gallery 30" Self-Cleaning...
My range is actually the RGB746 self cleaning gas
oven don't stay on and it takes a long time to heat up
Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
Lost instructions - I have my oven cleaning how
Typical oven self clean cycle is 3 hours. Oven needs to cool down to under 550 degrees before door will unlock. Download a use and care manual at http://www.geappliances.com/service_and_support/literature/
Nov 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Kitchen Ranges Logo
89 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
