Cannot start dubbing
When i switch on it shows DVD DISC FORMAT no matter if set on HDD or DVD after a few minutes it shows ERROR- CANNOT DO DUBBING NOW.
When I press ENTER it then clears the screen.But whenever I try to start dubbing HDD-DVD or any other it keeps showing ERROR-CANNOT DO DUBBING NOW.The only dubbing it will do is HDD-VCR or VCR-HDD.
Hope you can give me some help with this problem. Puzzled Pete.
    Scholar:
  • 135 Answers
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Posted on Jun 23, 2008
I have been dubbing DVDs in high speed in SP mode successfully, but am not able to do so in LP mode. My DVD recorder shows error everytime whenever I attempt to record a DVD in LP mode.
There's a setting to record in high speed mode and I suggest you always do that. If a recording in SP doesn't fit on a standard disc I think you will find it won't dub at high speed either
Sep 16, 2010 | Panasonic DMR-EH60 DVD Recorder/HDD...
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
JVC SR-DVM600 Dubbing from HDD to DVD Problem
Have you tried using a different brand disc. When I first purchased my DVM-600 it would not record on Memorex discs. I purchased TDK -R discs and all is fine. In the old-school analog world, all specific format tapes were computable to all machines. In other words, a VHS tape recorded in your VHS recorder will play back in my machine and every other VHS machine. Because the DVD format has so many formats and standards, compatability issues are quite common.
May 07, 2009 | JVC SR-DVM600
Recorded onto my lg rh397d/rh399d, want to copy to dvd
You need to read page 37 "Dubbing a title"
Select the title you want to record and select the Dubbing option.
Apr 06, 2009 | LG Televison & Video
I have a hdd/dvd recorder model rh7880/rh7500 set timer recording to record onto dvd, machine switched itself on as normal but did not start to record and froze up.cannot get anything to respond either...
Recorder wasn't under warranty, so opened the unit up removed the dvd - rw disc ,which was corrupted as it turns out, put the machine back together switched it on and it worked perfectly.I have since tested it by recording both on to dvd,hdd and used the dubbing format and have had no problems.In the future I would recommend bying only top quality discs as it seems a dodgy one was responsible.
Jun 29, 2008 | LG Televison & Video
HDD>DVD dubbing.....stopping, creating coasters
Still unable to find a solution for this problem. No response from JVC on their product either.
Jun 25, 2008 | JVC SR-DVM600
Dubbing from HDD to DVD disc
I beleive you can only dub from hdd to disk,
Try formatting the disk first.
good luck
Norm
Apr 03, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG RH265 - Problem when trying to register blank disk/dubbing
The DVD needs to initialise the disk first. Come out of the HDD dubbing menu and press DVD on the remote. The blank recordable disk should be recognised and you should see Initialise disk? on the screen. Press Start and hey presto, you can now dub from the HDD Movie dubbing menu (as per the manual instructions).
Feb 15, 2008 | LG RH177 DVD Recorder/HDD Recorder
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
Dubbing rom hdd to dvd
All you have to do is select dvd on the remote (at the top). Then it should do it automatically. If it doesn't, go to menu, then setup, disk, format. That does the job.
Nov 17, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
