Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic plasma vieta
When turn on tv the red indicator light goes on and then flashes - no picture
  • emschnei Jun 23, 2008
    Turn on TV , screen is black, no audio, red power light is on and flashes 1 long and 11 short. CAnnot turn off TV using power button. Must unplug. Is the flashing an error code? What needs to be fixed on this TV?
I just had this same problem and Panasonic says that it shuts down due to incompatibilities with a PC signal and HDMI 1 and 2. HDMI 3 is designed to work with a PC. If you unplug your HDMI and turn the TV off and then back on, it'll work. You can then plug your HDMI back in.
Or, you can just use HDMI 3 and the problem shouldn't happen again.
Posted on Aug 04, 2008
  • 4 Answers
I just bought a Panasonic TH-42PZ800U and had the same problem. 10 blinks and the TV would not start. Then after some trial and error I solved the problem!
Here is my (apparent) observation and solution:
I had only one input into the TV, which was my HTPC connected via a DVI-to-HDMI cable plugged into the Panny's HDMI 1 slot. *IF* the HTPC was already on, then the Panny would have the blink of death. *BUT* if the HTPC was off, the Panny booted fine (assuming I cleared the blink of death first by powering off the HTPC, unplugging the TV, and replugging the TV back in with the HTPC still off).
My solution was to move the HDMI cable from slot 1 to slot 3. After making this one change, everything worked as it should. No more 10 blinks of death. I could even leave the HTPC on and turn on the TV last, and it still worked. Tried this 10 times, worked 10 times.
I don't know if this will solve other people's problems, but I hope it at least provides some clues. I wonder if this is a fundamental circuit design flaw on the part of Panasonic, rather than a "bad batch of parts" problem.
Thoughts? Feedback? Send to gcpien at hotmail dotcom
Posted on Jul 03, 2008
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
Power light red no sound no picture
Red light is standby, it turns green when TV IS turned on. If the red light is flashing then there is a problem and number of flashers are a code to indicate a fault type.
Sep 19, 2013 | Panasonic TC-P42X5 42" 720p Plasma HDTV...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
643 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
