Question about Samsung YP-K3 MP3 Player
YP-K3 stuck on repeat
It keeps repeating the songs, even though in play mode I've set it to normal...it even says "nor" on the upper left hand side of the screen. Any solutions?
Its not your fault, of course. However, it'd help if you try reformatting the device. If not, even upgrade the YP-K3 into a new firmware. (Go to samsungplay.com, and download the newer firmware there. The firmware is new if the number of the version is higher than yours). It may help. If the problem persists, i'll try to find other ways to tackle this problem.
Posted on Jun 15, 2008
Keeps repeating
You can simply "set the repeat mode" to OFF:
1. Play the song.
2. Tap the now playing screen.
3. On the Now Playing screen, you will now see play and volume controls at the bottom of the screen. At the top is track information. Under the album title is a scrubbing bar that indicates the time remaining in the song.
4. A small icon that looks like two circular arrows is on the left side below the scrubbing bar. Tap this icon once to repeat the album. The icon will turn blue when repeat is activated.
5. Tap the icon again to repeat the current song. The icon will change to show the number 1 inside a blue circle.
6. Touch the icon a third time to cancel any repeat. The icon will turn white when it's deactivated.
Nov 22, 2013 | Audio Players & Recorders
I have music on my player but it will only play one song. On the display screen it has 2 arrows on the left side
I am guessing that it is set on repeat. In this case, while a file is playing, you can enter the Music Sub-menu by pressing the "M" button briefly. There you should be able to change the repeat mode from "Repeat One" to "Normal."
May 03, 2011 | Eclipse CLD2 MP3 Player
The songs are stuck on repeat. wont change to the next song on its own, has to be done manually.
When song is playing tap center of display to bring up settings.On left side tap the two arrows following each other to turn off repeat function.If a two is showing this repeats current song only.No number repeats all songs when reaches end.
Nov 08, 2010 | Apple iPod touch
Playing by album
To change the play mode on the GPX ML648B you need to play a song, hit the MODE button on the side of the player and select Play Mode.
The options are INTRO (this will play about 10 seconds of a song and then go on to play the next 10 seconds of every song.) NORMAL which will just continually play through everything on your device, Repeat One, which will repeat one song, FOLDER which I'm not sure of, FOLDER REPEAT which I assume repeates a folder, REPEAT ALL and RANDOM.
May 19, 2010 | GPX ML648B MP3 Player
When my iTouch is in suffle mode it plays the same song untill i manually change it. i reset all the settings and it works great for a while but eventually it goes back to repeating the songs again. is...
when you are playing music, look at the top of the screen holding the iTouch vertically. (longer end up and down) Now look towards the upper part of the screen and you will on the right side two arrows criss crossing, this is the shuffle, and on the left side of that you will an arrow circling itself. Touch the arrow that circles itself until it's white, which means that the repeat feature is turned off. If it's blue, the repeat is on and is the cause of your issues. Let me know.
Jul 21, 2009 | Apple iPod touch
It will not let me change a song
have you checked the following,
i the setting of play repeat, or repeat all.
ii all its on repeat with only one song
iii check how many songs are in your set
Feb 17, 2009 | Samsung YP-K3 MP3 Player
Not skipping the next song
yah. I think you put it in the repeat mode.
Click on a song, click the right button at the bottom of your screen and take it out of repeat mode.
If that doesn't work i don't know so you should cally samsung.
i hope this helped.
Jan 24, 2009 | Samsung YP-K3 MP3 Player
Stuck on one song
try fiddling with the repeat option. you might have changed it and it just didn't register.
Jun 03, 2008 | Samsung YP-U3 MP3 Player
Samsung yp-u2j
Set the User Button Mode to and press the [ USER/ ] button. Playback mode changes in the following order each time the button is pressed . Hope this answers your query.
Jun 14, 2007 | Samsung YP-U2JQB MP3 Player
Samsung yp-u2j shuffle
Hold Down The M (Menu button) Scroll down to settings, select play mode. Exit out of he menu, press the user button until the squiggly cross with the A appears. Whalaaa you're in shuffle Mode. I hope this was a detailed solution.
Samsung YP-K3 MP3 Player Logo
95 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
