Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
Saeco vienna digital
Hi, my problem is I am getting a message that the DREGSDRAW MISS, even though the drawer is in place. Can you help and could you also forward a copy of the owners manual if at all possible.
Thanks for you consideration and help.
  • 3,037 Answers
Pull out the drawer and make sure everything is clean and that the sensor is looking good. Try unplugging it and replugging it in to try and reset it.
Here is a link to where you can download your manual
http://www.saecoparts.com/user/Saeco%20Manual%20SUP018%20D%20Vienna%20Digital.pdf
Let me know if you need anything else
Posted on Jun 07, 2008
  • Benjamin Patri
    Benjamin Patri Jun 14, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
  • 13,433 Answers
    President:
  • 2,712 Answers
Can you give me the exact model of your unit please?
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Tip
Hi, I found your description very interesting even though my machine is a Jura...
All of a sudden I had no steam and no water.
I could hear the pump chugging and trying hard, but nothing came out of the nozzle.
First, check to see if the nozzle is blocked. If it's not, try turning on the tap (faucet) and PUSH IT IN towards the machine.
If you now get steam and water, there is a quick fix.
Switch off the mains, unplug the coffee machine and take all normal precautions not to electrocute yourself.
There is a small cam on the (Part 9161205 - Faucet rod stem) which pulls the tap IN as it is opened and OUT as it is closed.
1] Remove the coffee container - there are two phillips screws only, and it lifts off.
2] Remove the top casing. There are two phillips screws either side at the front top, hidden by the door, one star head screw under the water tank, and one normal phillips screw under the water tank in a deep channel.
3] Take a look at the small cam on (Part 9161205 - Faucet rod stem) and see if it moves in and out as you turn the water/steam tap on and off. If it doesn't the plastic has sheared off. If it does move in and out - this is not the fix for you!
4] If it does NOT move in and out as you turn the water/steam tap on and off, find a small self-tapping screw and screw through the angled cam hole into the faucet rod stem. Pop the top casing and the coffee container back on and your machine is now fixed!
Now for a delicious cappuccino62e2053.gif!
on Apr 17, 2009 | Saeco Vienna De Luxe Espresso Machine
Error message: Dregdraw miss
which machine do you have. The drawer is not hitting the micro-switch try puttin a piece or 2 of tape on the tab on the side of the dredge drawer
Nov 20, 2009 | Saeco Coffee Makers & Espresso Machines
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
I have a saeco vienna digital, it gives a message: Perc.un.ontbr. What does it mean?
Hi
Go into your menu (bottom left) and scroll (up or down arrows) to language. Push the "OK" button and change it to English and push the "OK" button. Your is on the wrong language.
Jun 21, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
Apr 10, 2009 | Saeco Royal Professional Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco coffe maker doesn't work
Thank you for your concern! I drove it over to place nearby that fixes these machines in Los Angeles. That way, I can avoid costly shipping charges!
May 24, 2008 | Saeco Vienna Digital Coffee Maker,...
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
163 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
