Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
Problem with GE Zoneline 5200 model
I have a GE Zoneline Heat Pump Model (5200 Series) which stopped cooling one day. It turns on and fan blows air and heating works fine. Its just when in cool mode it just doesn't blow cold air even if I set the temperature all the way to 60 F. All switched are DOWN except 8 and 9 which are UP (and I think those are only heat booster in cold chilly winter and fan cycle).
Can these units be recharged? Any other help please?
  • Anonymous Mar 30, 2014
    Model LEA12HZT2 - fan blows but will not cool heat is fine
  • 54 Answers
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
What are the setings for the dip switches model az28e12dabm3
We have the 2800 series manual posted online. You can get it at our GE Zoneline page.
Generally, the default settings work best, unless you want to set temperature limiting.
Aug 15, 2014 | GE Zoneline Deluxe Series Cooling &...
Condenser won't kick on, and is hot. Fan works? What's should I do?
Check whether the AC is on fan mode. There are two mode for this type. FAN and AC mode. Put it to AC mode and set the temperature. Solved!! :)
If it doesn't work, call the AC repair guy.
1) Either there will be error with the capacitor circuit which triggers the condenser.
2) there is an issue with your condenser and the circuit.
This is a small repair.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
GE Zoneline 1000 - heat stopped working this morning, A/C is working fine, fan is working fine, buzz sound when heat is turned on as normal, thermostat seems fine as room is still warm, can turn thermostat...
Sorry to read about your problem, I hope this helps you out.
Sounds like you may a defective, reverse heat pump switch. If you were in Denver,Co I would be glad to work on it for you. They are no different than large units to work on.
and no, you cant work on the unit.....takes special tools
Just keep calling around for a person who will work on the unit..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | GE Zoneline AZ25E12D3B Air Conditioner
Getting heat instead of cold
probably the evaporator is not good,and also there is no gas in the the circuit and when it blow air its only heat is coming out
Aug 22, 2009 | GE Zoneline AZ25E12D3B Air Conditioner
Heat pump not working?
First check your breaker panel and if thats not it check the fuses at the diconnect box for the condensor.
Apr 14, 2009 | GE Zoneline AZ25E12D3B Air Conditioner
GE Room Heat/Cool unit will not heat with heat pump
If it was me I would cnage the sensor first. Simply because it is way cheaper than the control board and these sensors are fickle as hell to begin with.
Dec 14, 2008 | GE Zoneline AZ55H07D Air Conditioner
How to best run this thing
Hi Laurelrobin,
When the unit is on "low fan", it is fan only, and is recirculating room air. If the damper is open, it can also bring in outside air. If the space is not occupied for extended periods, it's OK to turn the unit "OFF", as long as you have a newer unit with Heat Sentinel, and the Heat Sentinel is turned on. Heat Sentinel will not let the room temp get above 85F, as long as the unit is OFF. Also, in most cases it's best to keep the damper closed. You can check your owner's manual for more info on the Heat Sentinel and other auxiliary functions. I also have an article on the temperature limiting functions of the GE Zoneline.
Feel free to contact me at greg.mcnary(at) if you need further info.
Greg McNary
Air Distributors Company, Inc.
Louisville, KY
Distributors for GE Zoneline PTAC Units, Zoneiare PTAC Units, and McQuay PTAC Units.
Aug 01, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Ge zoneline hvac
Pls check following......
1) If the Fan run and the Blower not function its min loose the hub or screw of the blower ,fix the hub or screw .
2) May be the the shafting of fan motor not rotate, repair the shafting or bushing of fan motor.
3) Check the Capacitor if this low capacitance or open (not function) using Multi-tester to check the parts.
4) Check the Fan motor wire if this loose connection.
if does not working,go to the nearest repairman to help the problem.
Thank you & have a nice day
Jan 24, 2008 | GE Built-In Room Air Heat Cool Air...
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
476 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
