Question about Canon PIXMA MP150 All-In-One InkJet Printer
My MP 150 was working well until I replaced the ink cartridges. Now each time I try to print I get a message saying 'The printer is offline. Check that the printer cable is connected and the printer power is on.' Have tried everything, changes cable, reloaded the software, replaced the old ink cartridges without success. Any advice please? Jim
    Guru:
  • 1,342 Answers
Try this to re-set your printer:
Canon MP150
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
Posted on Jun 07, 2008
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Printer offline which was working earlier
My computer detected printer offline. I have just used to print some documents. So, please advise what is the problem.
Mar 28, 2013 | Canon Black Pixma Mp 280 High Quality...
I can not get anything to print on my Epson NX420 using my IMAC. It says the printer is offline and I can't even print a test page. Can you help?
I'm assuming the printer worked previously from the iMac and now it does not. If you never had it connected, please add a comment to this effect, and include your OS version.
First, Open the Print Center (Printer Utility) and check the status of the printer. It may be listed as stopped. If so, delete any extra print jobs (additional attempts to print the page), then click the Start Jobs icon.
You can verify printer connectivity by clicking Add in the Printer List (if that is not visible, select Show Printer List from the View menu). Be sure to select either the USB or wireless network protocol connection. If the NX420 shows up, you have a good connection. In that case, click cancel and skip the next paragraph.
If you are printing via USB, check the cable (I sometimes forget to plug in my printer cable after downloading from my camera). If you are printing via your wireless network, check the status of the wireless connection from the printer.
Also, in the printer utility window, click the Supply Levels icon to verify that all of the ink cartridge levels are high enough to permit printing.
Are there any error messages on the printer display? A fault detection will take the printer offline.
Jun 22, 2011 | Epson Printer
Printer offline
Several printers are connected to my Dell and sometimes without paying attention I forget which printer I'm using. On your print set up page scroll down until to your printer and select it. If you have only one printer, then select it as your default printer.
Jul 01, 2010 | Brother MFC 7840W Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Use of High yield Cartridges in Canon Pixma 150
have u tried to remove the cartridge again, proably some contact problem
May 27, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Pixma MP150 won't print
i cant help you with your problem completely but every time i change the ink the printer states to install the correct cartridges and or that my ink level is low and will not print
all previous occasions with the cannon mp150/160 if there's such a word as stubborn can apply to computer printers i have had to keep rebooting the programming that is switching off and on at length the power supply until the printer finally works or offers the alternative message to press the start button
i have 2 cannon printers mp150 and mp160 because it is just about the same price to buy a new printer than 2 new cartridges
keep rebooting it may take up to 15-30 minutes!
Nov 25, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Constant error message
Check the manual on how to RESET the printer. It is not always revealed - some makers like to keep some things secret from users. If there is not a separate RESET button or the manual does not tell you, then try pressing various buttons in the printer section in combination with the power off and whilst holding the down- power up. It will be a trial and error thing - so if you do find it- make note of it for you and post it here. Mean while do go to Canon Website and ask Tech support Also take a look at www.fixyourownprinter.com
May 19, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
89 people viewed this question
old marine
old marine
