Question about Brother MFC 1850MC Thermal Printer
Fuse blown As soon as i plug the machine into the power outlet it blows the fuse located inside the 1850 mc
    Problem Solver:
  • 13 Answers
Sounds like the smpsu (power supply)is faulty.
if the fuse is black inside it means there is a s/c
on the psu if the fuse is clean it generally means
a faulty component on the board.
Either way replace or repair psu.
mongrelken.
Posted on Jun 07, 2008
    President:
  • 2,712 Answers
Make sure the voltage settings are correctly chosen, or you have the correct power adapter.
Fuse is blown = need to replace, what type of fuse should I use
How to Change Treadmill Fuses ' LIVESTRONG.COM
www.livestrong.com > Sports and Fitness
Sep 29, 2015 - If the fuse on your treadmill has blown, it's time to replace it. ... Thetreadmill fuses are located inside the elevation motor. If you don't have the ...
Treadmill blowing fuse. ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Sep 1, 2014 - I have recently picked up a second hand treadmill with an issue (York Challenger ... If I unplug the motor from the control board it will not blow the fuse, and will give ... Not sure yet, but i'll replace the IGBT's/power mosfet (I still don't know whats ... Treadmill goes high speed then blows the fuse
Nov 25, 2015
Treadmill blows fuse as soon as it starts
Sep 29, 2015
treadmill motor controller problem?
Aug 25, 2012
Treadmill Controller - No power to motor
Feb 11, 2012
More results from forum.allaboutcircuits.com
Jan 20, 2016 | Exercise & Fitness
THE MACHINE IS PLUGGED IN AND DOESN'T SHOW ANY POWER. I CHECKED THE OUTLET AND IT'S GOOD. WHAT IS THE PROBLEM?
Try checking the fuses in the back next to the plug. If they look burned or blown replace them. If the problem persists after the fact, the entire Plug Holder and Fuse Block may need to be replaced. Sometimes when the fuses blow they leave a black discharge on the contacts inside the fuse block rendering the fuse block useless and powerless.
Apr 13, 2011 | Lavazza Espresso Point Capsule Machine
All power outlets went out. I replaced the fuse in the side panel but, as soon as I plug anything in, I can hear the fuse pop. I have checked all the other fuses andit is the only one that is blown.
You will need a new power outlet / cig lighter socket. The side tabs can get bent, and it will internally short and blow the fuse, whenever something is installed. Visually look inside the socket to see if the 2 side tabs (ground) are bent inward or downward. The center dot at the very bottom is the power, if it touches the sides or the tabs it will blow the fuse. It could also be the appliance you are plugging in, try something different (like a phone charger).
Apr 08, 2011 | Dodge Durango Cars & Trucks
Recieving no power even though plugged into good outlet. is there a fuse?
Hello
Ofcourse there is a fuse in the AC track of every TV. But if fuse must blow, there must be some reson for that. Fuse is included in the path of AC as a protecion to the circuit for over voltage of over current. Just look inside, and confirm the fuse is blown or not. If blown, find out the reason for that and tectify it before placing an other fuse in place. Otherwise, the fuse you replaces will also blow out. OK.
Feb 17, 2011 | Hitachi 57F500 57" Rear Projection...
Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
Oct 13, 2010 | RCA 32F531T 32" TV
Washer does not power on and is getting power at the outlet
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Power outlets don"t work
Be sure what you are plugging into the outlet has the same polarity as the outlet itself. Some of todays accessories being foreign made have a reverse polarity versus american made cars.
Jan 09, 2009 | 2005 Jeep Grand Cherokee
2002 Dodge Intrepid, Power outlet\Cig lighter not working
fuse should be located the end of the dash drivers side
Jun 25, 2008 | 2002 Dodge Intrepid
Brother MFC 1850MC Thermal Printer Logo
348 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
